Anyone have a good source for better springs for the front of an
SE? Maybe a slightly larger outside diameter wheel which will fit the stock ZZ hub/wheel cap combo?
Was thinking about swiping the springs from my Jeep ZZ, but they appear to be slightly larger in diameter and are pretty soft. When I noticed how soft they were I was thinking about adding the softest suspension bar in addition to the stock springs.
if you want them to be stiffer take the spring out of your se and streatch it to just about twice its size and then re install,, it will be much stiffer
This is what i did with my xmod and it worked great
