Old 10-23-2004, 04:13 PM
moebrown20's Avatar
moebrown20 moebrown20 is offline
Send a message via Yahoo to moebrown20
Single shock
Here is a site I visited that has detail instruction for a single shock. http://www.okcxmods.com/forum/viewtopic.php?t=28
Old 10-24-2004, 03:25 AM
wacko_boy wacko_boy is offline
Send a message via AIM to wacko_boy
thanks awesome tut.
Old 10-24-2004, 09:40 PM
viperdout's Avatar
It's Really Fast!
The mono-shock is a waste. Put in a really stiff bar in between the 2 suspension mounts, and it handles much better.
Project Bad Brushless:
Just say no to giant sigs.
Old 10-25-2004, 01:52 PM
allaboutav allaboutav is offline
Send a message via AIM to allaboutav Send a message via Yahoo to allaboutav
Actually when setup correctly this mod can really help with getting realistic traction in the rear when throwing the car into corners. I have found that, depending on the track, with the right spring setup you can decrease your turning radius by quite a bit, because of the grab that wheels have with this mod. Basically the two wheels "feed" off of eachother to keep both wheels on the ground. I am doing one right now using GPM alloy dampers, it should be very responsive.
I am not sure what you mean by "a really stiff bar in between the 2 suspension mounts". The rear deck does this already. Can you explain? Maybe I misunderstood.
AllAboutAV
OKCXmods Racing League
www.okcxmods.com
Old 10-25-2004, 03:51 PM
Phred168 Phred168 is offline
yeesh. Not only would that be tough, I'd be scared to bugger up 10 dollar shocks...
1997 Red Toyota Supra (It finally bloody runs!)
Mods:
2 cell Lithium-ion batteries
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
1965 Ford Mustang :Bone stock
Old 10-25-2004, 05:21 PM
viperdout's Avatar
It's Really Fast!
Ok, imagine you have your shocks still on, and itstead of the mono-shock, it is replaced with a piece of very stiff plastic. It pushes down on the opposite wheel when one looses traction.
Old 10-25-2004, 07:29 PM
spinitsidewayz!'s Avatar
boro dori style RC
take a piece of thin plastic or something and drill holes for the shocks to mount through. thats what viperdout is trying to explain. it works very well and keeps your rear end planted instead of hopping around like stock or even a mono-shock which i think is worse..
adding a bar it makes the rear suspension work as one, as well as with varying lengths you can adjust camber settings. i am using a cut up broken guitar pick cut short for a bit of negative camber. makes the rear end much more predictable, especially with lsd.
r34 - rwd
r34 - awd
dd4 - fwd
Old 10-25-2004, 08:07 PM
viperdout's Avatar
It's Really Fast!
Exactly, except don't use too thin of a plastic, or it will just bend. I personally like the plastic off of ZZ packaging.
Old 10-25-2004, 11:22 PM
Very cool. I haven't tried that yet. You, if I am reading this right, get the benefit of independent suspension as well as the added pressure from the opposite wheel's reaction to the ground.
Makes sense to me. I will try it this weekend. Any particular tension on the springs?
AllAboutAV
www.okcxmods.com
Old 10-26-2004, 03:11 PM
viperdout's Avatar
It's Really Fast!
Not really.
Old 10-26-2004, 11:54 PM
BoomTap BoomTap is offline
That is a great idea. Taking the shocks off and trying to find the springs after they fly accros the room was driving me nuts.
Go Fast.
Old 10-27-2004, 12:32 AM
Here is a pic of what I think viperedout means. I found a pic that I saved from somewhere a while ago. I cropped the image to just show the rear suspension.
Old 10-27-2004, 12:58 AM
boro dori style RC
yup thats right. really improves traction and predictability. i wouldnt be able to stand driving w/o them.
http://www.tinyrc.com/forums/showthr...light=sway+bar
i have no clue why i called it that. it acts nothing like a sway bar... a better name would be like a traction bar or something? lol
r34 - rwd
r34 - awd
dd4 - fwd
Old 10-27-2004, 01:46 AM
I have a beach ball...
Looks like a sway bar to me. I may have to try that.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 10-27-2004, 02:08 PM
viperdout's Avatar
It's Really Fast!
Exactly what I meant!
Shock Upgrades!!!! Home-made!!! Keono Micro-T Parts and Hop-Ups 7 03-19-2007 10:27 AM
best single speed bit bdnunchaku Bit Char-G / MicroSizers 23 03-06-2006 03:22 PM
Invivible Shock J-Tuner XMODS 2 03-01-2005 07:34 PM
MONO shock and suicide hood wordlyfe XMODS Mods and Projects 0 02-02-2005 05:01 PM
Mosfet Power for single Cell Bitīs!!!! Grasziege Bit Char-G / MicroSizers 10 02-06-2003 09:34 PM
