Old 09-05-2004, 10:08 PM
Phred168 Phred168 is offline
A bit of an odd question
While I was snoopin' around on allelectronics.com, I came across these motors:
http://www.allelectronics.com/cgi-bi...224&type=store
Basically, an in-hub electric motor. Any idea as to how they'd adapt to an xmod?
At 6 Vdc they turn at approximately 9700 RPM.
Old 09-05-2004, 10:56 PM
micro kid's Avatar
Do you getto dremel?
i dont think you have a chance of converting them over to XMOD use. you could make a sweet quad motor RC car with them though just not in an XMOD
Old 09-05-2004, 11:31 PM
SHIFT_DRIFT's Avatar
5Zigen
They would run way too slow.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 09-06-2004, 09:45 AM
At 30000 RPMs (totally unrealistic) and the white pinion set(6:1), the wheels are spinning at 5000 RPMs. Thus, the question is more of fitment,power, and the like than whether or not it'll spin fast enough.
Old 09-06-2004, 02:45 PM
5Zigen
You can maybe open up the motor, and see if you could attatch a pinion onto the wheel. (or if there is a shaft) I don't think it would fit in the motor bay to well though.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 09-06-2004, 06:34 PM
Never hurts to try Maybe I'll order a set this week and see what happens.
Old 09-12-2004, 08:32 PM
hotrod29728's Avatar
Go ahead and buy a set... Wire them directly into the motor wires and see what they do... Just mount them to the chassis were the old cups/joints/axles/tires would be... That would take alot of weight off of the car... Just try... You never know...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 09-13-2004, 05:16 PM
Kevmiester's Avatar
Kevmiester Kevmiester is offline
Ferrari rox and so do i
you shoyld buy 4 of them and use each of them as a wheel. get different wheels thing so you have grip and go. if would look like a futuristic car though
Skyline with RS graphics
All RS upgrdes
4.5 Stiff/front Medium/back
9 tooth drag motor
GTR Xtreme kit from cXp
Custom internal intenna
Custom lights with fogs and tailpipe
Mono-shock in rear
Red Ferrari 360 modena body in the works
Old 09-13-2004, 06:31 PM
You really could only use two other wise you would need FETs to give it more current... And Li-Ions probably... Plus, how would you steer? I guess it would be primarily drag...
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
Old 09-13-2004, 09:20 PM
Already have li-ions And I suppose i could rig up a bit of an odd tierod system to use w/ the stock servo. Just mount the wheels like on the stock suspension, more or less. Not the actual suspension, of course, because extensive modification would be required. but at any rate, I wont be ordering anything until Ivan's blown by (I like in Panama City, Florida. Right in the middle of "You're screwed" alley)
Question about the Bit Char-G body sets Gaian Bit Char-G / MicroSizers 2 01-30-2004 07:09 PM
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 10:04 PM
Bit Char-G Supra question. . . andrzejpw Bit Char-G / MicroSizers 21 07-30-2002 07:34 AM
