View Poll Results: To Slot or Not To Slot?
Keep it smooth and simple 11 20.37%
Slot it 43 79.63%
Voters: 54. You may not vote on this poll
Old 01-07-2004, 06:47 PM
Zero-Man
To Slot Or NOT To Slot, for the battery clips that is
Need your input on this one........
Wanted to keep the bottom of the X-Mod CF chassis as clean as possible, but I ran into a compromise issue. The Stock Battery Clips are harder to remove since there is no way to get to the bottom of the clip. If you back off the screw that holds the battery box and rear top plate about 1 turn, then the clip will come off with a little effort. See the Pic........
Vote for your choice, slotted or not
Old 01-08-2004, 08:48 PM
QPizzle QPizzle is offline
Send a message via AIM to QPizzle
function should come first..SLOT IT!
Old 01-09-2004, 02:05 AM
mystiquesupra mystiquesupra is offline
I agree, looks sharp... but dont give up the ROUTINE use of the clips.
Function before beauty
Old 01-09-2004, 10:21 AM
neurokinetik's Avatar
Slot it. Saves weight in the process anyway. Actually, for stock setup, why do we need all that material underneath the battery holders anyway? That's just added weight and unneeded, IMO.
Old 01-09-2004, 01:47 PM
hoopsta1423 hoopsta1423 is offline
i say slot it aswell, it would take even more weight off, and btw whatr is that hole under the front gear for??
Old 01-09-2004, 02:20 PM
It is to keep the gear from rubbing on the chassis. Take a look at a stock XMod chassis and you will see why it needs to be there.
Old 01-09-2004, 03:51 PM
Skurge420's Avatar
Skurge420 Skurge420 is offline
Gerbil Racing
Send a message via AIM to Skurge420
damn......slot it
cant wait for these to come out!
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
Old 01-09-2004, 07:18 PM
maxximum attack
OFF TOPIC:
I am a little cancerned with that front differential. How do I keep dirt from being picked up by that gear. (aside from a skidplate)
Old 01-09-2004, 07:25 PM
Zero-Man
Yep, a concern of mine too, the issue is one of those compromises I talked about earlier. In order to keep it light, I wanted to use the 1mm CF and not the 1.5mm CF. The thicker the chassis, the more rigid, the heavier and also the more "lift" to all the bolt on components. In reality the diff barely extends below the bottom of the chassis. But it has to be open for clearance. Low nap carpet shouldn't be too much of an issue. High nap or loose gravel could. Simple enough to rectify with some double sided tape and a small square of thin clear plastic, bet you have them laying around the pit bench somewhere........
Originally posted in the CF Chassis thread...................
Old 01-16-2004, 08:10 PM
Plus you could always throw some plastic soda bottle under the chasis(bolted with stock bolts holding suspension tight) for a makeshift skidplate that would also act to keep crap out of the differential.
Old 01-16-2004, 09:37 PM
Zero-Man
Spot on; now that sounds like a tinkerer's solution to me.
Old 01-17-2004, 02:13 PM
T Man T Man is offline
How many people are going to get the CF chassis and keep the stock electronics? To me, keeping the stock electronics seems to defeat the purpose of buying the chassis.
Old 01-17-2004, 10:27 PM
RGM1524 RGM1524 is offline
Send a message via AIM to RGM1524
I have a question... exactly what electronics are you planning on using. Seems like there still isnt very much room to work with underneith there for hobby class electronics.
oh yea and... slot it!
-Colin
Old 01-18-2004, 02:20 AM
The purpose of the chasis, atleast IMO, should be to lighten the load on the motor by reducing weight. I will keep my stock electronics, with the addition of a FET upgrade it will be more than ample.
Old 01-23-2004, 12:30 AM
microINNOVATION's Avatar
microINNOVATION microINNOVATION is offline
TinyRC Innovator
Send a message via AIM to microINNOVATION
I AUCTUALLY DIS AGREE DONT SLOT IT FOR THE SAKE OF AFRETMARKET PARTS YOU NEED THAT EXTRA ROOM FO THER STUFF NOT TO MENTION IT WILL ENCOURAGE PROPLE TO GO BUY HOBBY GRADE RECHARDAGABLE BATTERYS NOT AAAs
IF YOU LIKE THIS MOD OR ANY OF MY OTHER MODS CHECK OUT OUR SITE AT
HELP!!! battery clips custummodz XMODS Parts and Hop-Ups 5 08-23-2007 01:57 PM
Wanted: Xmod receiver with battery clips and pcb all 1 piece. newbitowner For Sale/Trade 4 07-31-2004 12:36 PM
Battery Runtime Tests Namuna Bit Char-G / MicroSizers 25 09-20-2003 09:35 AM
