Old 06-18-2006, 11:34 PM
iphong iphong is offline
Project: Monster Hummer
This is my little project I want to share with you. This is my second HUmmer after the previous one has crashed with a 1:1 scale truck yesterday and I had to dump it.
I don't use lift kit in this Hummer for several reasons, first, because of the toe out problem. Second, my wheels is big enough to have lots of ground clearance, and third, it has lower center of gravity therefore it handles better. My last hummer always toppled during tight turn.
Enjoy!
Old 06-18-2006, 11:48 PM
Namuna's Avatar
Namuna Namuna is offline
Wow, those are some wild tires. What are they from?
Big fatties like those makes me think your monster is amphibious!
Old 06-19-2006, 07:56 PM
Jazz32
How well are those tires secured? They look a little floppy to me.
Old 06-19-2006, 09:14 PM
flamehead_16's Avatar
flamehead_16 flamehead_16 is offline
Naruto Champion
i have done that before and i could only run them on the rear because the front would not turn. there rims are loose fited in.
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
Old 06-19-2006, 11:07 PM
The tires is very secure on the wheel. I install AWD kit and 4 wheels rotate as fast as the lift kit's tires. I will upload some videos. It runs fast, it climbs slopes and it jumps.
http://x.iphong.com/hummer.avi
Old 06-20-2006, 08:03 AM
Naruto Champion
cool i have to try that when i get my bearings in fir my truck
Old 06-20-2006, 08:06 PM
Jazz32
Could you get some videos up of that thing driving around. I'm still a little concerned with seeing how it turns. I was thinking the turning motor might have some problems moving those bigger tires. You might also want to add a few more cells to that.
Old 07-09-2006, 11:54 AM
ZERO ZERO is offline
That is pretty awesome, but u probably could install the lift kit. That insane tire width should still be able to make up for the higher center of gravity. It'd be cool if u could find some rims that were big enough for the tires. And the steering shouldn't be too bad anyways right? When it gets going, steering is obviously easier. Did u get those tires off of some lego set?
one step at a time
Blue Monster Project iphong XMODS Gallery 6 07-21-2006 05:18 PM
Project: Monster Mater Michael.mt2k ZipZaps Monster Truck 7 06-23-2006 11:57 AM
Planning Micro Monster Project DanielS TTTT 4 09-18-2003 04:49 AM
Monster Hummer!!! Buzzbait Bit Char-G / MicroSizers 5 06-26-2003 06:22 AM
My new project - Monster Bit Ovgron Bit Char-G Mods and Projects 23 06-23-2003 12:51 PM
