04-26-2004, 02:52 PM
Xmods Battery Question
how long does it take to charge 4 aaa with the xmod battery set. and do they charge aa's thanks
04-26-2004, 02:57 PM
About 15-30 minutes, and NO AA's.
04-26-2004, 06:54 PM
I'm not a pyro, really.
yes AA's, read the instructions. i assume you're looking at the charger with 8 AAAs that is next to the XMODS stuff? they charge AAs. i would venture to day 30mins -1 hour, 15 min is only the IC3s. i would reccomend spending the 40+ dollars on the RAYOVAC IC3s. the RS IC3s cost more and arent as good. the RS IC3s dont charge to 1.7 volts like the Rayovac ones do.
NEVER UNDERESTIMATE THE POWER
04-26-2004, 07:03 PM
so the XMods rc Rechargable battery Kit is ic3 technology??
so it takes them 30 - 1 hour to charge thats cool for only 25 with 8 aaa's
04-26-2004, 07:05 PM
he is talking about the XMODS charger that only charges 4 at a time. Link here: http://www.radioshack.com/product.as...%5Fid=23%2D350
It says it will charge AA's, but they do not fit very well at all and take forever to charge. The AAA's will charge fully in 30 minutes
As for the IC3's, they are 1.2V just like EVERY other NiMh battery. The only advantage is the 15-minute gimmick charger.
04-26-2004, 07:13 PM
at peak charge they read around 1.7 volts.
and not every NIMH battery is 1.2 volts. i have a couple of NIMHs that are regular C sized batteries that are labeled 2.4 volts. un
04-26-2004, 07:19 PM
how many MAH are they. thanks alot xmodspeed and aperson youve been a great help. i love these forums
04-26-2004, 07:24 PM
the RS NIMHs are 700 MaH (MaH millamps per hour)
the IC3s are 800 MaH
04-26-2004, 07:27 PM
No, all NiMh are 1.2V! The ones you have are not 'C' cells then. There are regulations behind the markings of 'AA', 'AAA', 'C', and 'D'. One of them being not to exceed 1.5V nominal. Otherwise battery companies would be burning up electronics devices everywhere.
BTW, that 1.7V off the charger is common among ANY battery. Put a load on it by placing it in the XMOD and measuring it even after fully charged. You'll get 4.8V which is 1.2V/4.
04-27-2004, 08:37 AM
when i said "C sized" i meant physical size its close to a regular c size.
