Old 10-10-2002, 06:04 PM
Spitfire7001 Spitfire7001 is offline
LED Mod
this isnt much but looks cool.
Its some LEDS i put in my back window of my zipzap.
Here is another view
thats about it.
Enjoy
My ZipZap Mod Site
www.sal.wronger.com/mods.html
Old 10-11-2002, 03:54 PM
joeNuggetz joeNuggetz is offline
nice.
Old 10-11-2002, 04:35 PM
Rodzilla's Avatar
Rodzilla Rodzilla is offline
Headlights
Looks cool. Has anyone made headlights for a ZZ? I'm wondering how well it would work to scrape off the paint covering the headlights and put some working lights inside?
Old 10-11-2002, 04:49 PM
lnx_author's Avatar
lnx_author lnx_author is offline
Join the GNU Generation!
LED mod switch - better?
- just did a red LED brake-light mod for my yellow Ford Cobra zz...
- however, instead of using a microswitch (as shown elsewhere), i desoldered a 2-pin mobo jumper off a junk ISA card, drilled two holes by the zz's gas cap, and mounted the jumper from the inside... to turn on the lights, a jumper is placed on the pins - when not in use, the jumper is placed on only one pin...
- this approach is cheaper, less obtrusive, and saves several grams of weight for the mod...
- i also used the smallest 3V Lithium cell i could find...
all in all, a very nice $3 mod for my zz...
Old 10-11-2002, 05:00 PM
Rodzilla's Avatar
Sounds cool. Do you have any pictures?
Old 10-11-2002, 10:11 PM
lnx_author's Avatar
- will do when i get some time...
- i thought about mounting the pins to come out of the license plate, but there's no room...
Old 10-12-2002, 12:02 AM
Re: Headlights
Dude, great idea with the jumper thing. I need to try that. All the switches I have are broke and are 2 damn big. Thanks for the tip.
Old 10-12-2002, 01:34 PM
lnx_author's Avatar
mobo pin switch - on
dunno if you can tell, but the LEDs are on:
Old 10-12-2002, 01:37 PM
lnx_author's Avatar
mobo pins - LEDs off
here's the unit w/LEDs off (jumper sits on one pin)... btw, you could use this arrangement with a 3- or 4-pin mobo set to:
- have backlights on, headlights off
- have headlights on, backlights on
- have headlights on, backlights off
Old 10-12-2002, 03:20 PM
s1rGr1nG0 s1rGr1nG0 is offline
Its kinda cool, but, you've got this big jumper sticking off the side of your car!
Old 10-12-2002, 03:32 PM
lnx_author's Avatar
yer right... mind you, this was a first attempt... however, it is lighter, the pins could be trimmed, and the jumper really isn't that big (i can barely see the pins or get the jumper on, but then i'm a half-blind, overweight, ham-fisted 'ol phart with carpel tunnel)...
i'd prefer to have the jumper underneath or out the license plate area, and will try for better placement on another try...
Old 10-12-2002, 04:11 PM
Rodzilla's Avatar
Hmm...maybe there's a way to modify the spoiler to act as a jumper since those car bodies already have the two holes and the spoiler removes easily? Might be some tricky wiring involved.
Old 10-12-2002, 11:56 PM
latency latency is offline
Likely seen this...
But check out this link from QFM....I think QFM has a link to a guy that actually had working break lights and turn signals. I saw video of it and was in tears!!!
http://www.cflowers.freeserve.co.uk/mike_mods.htm
skinny sig
Old 10-13-2002, 12:55 AM
Go0ty's Avatar
Go0ty Go0ty is offline
funk master flex
Send a message via AIM to Go0ty
holy hell!
look at those lights! that's freaking amazing, if you also look on his site he'll install all that on your car for a mere 50 bucks
LED Mod - Flash to pass (Get your minds out of the gutter). X_I_Ted Bit Char-G Mods and Projects 6 07-02-2003 07:03 PM
Best Lightest LED MOD! scottyboyfun Bit Char-G / MicroSizers 9 01-07-2003 02:40 PM
Led Mod Problems pakiplaya Bit Char-G / MicroSizers 1 12-18-2002 06:31 PM
Assistance with LED MOD please help a newbie SmokenRubber Bit Char-G / MicroSizers 0 12-04-2002 05:02 AM
