Old 05-16-2004, 11:32 PM
cdog4w's Avatar
cdog4w cdog4w is offline
newbmaster
motor mount modification
Has anyone modified their motor mount to allow certain motors to use larger pinions? I had the problem with a TO Core Modified and now with a TO Elite Modified that the bushing on the outdrive is so large that it prevents the motor from being positioned far enough away from the axle to let you use a pinion larger than 10T. My plan is to use my dremel and a tungsten carbide cutter (drill bit shape) to widen the center hole to allow the motor to be positioned further from the axle. Since its not a large bit, hopefully I can enlarge it just enough for my needs.
Has anyone tried this? I want to ask before I possibly destroy a $15 motor mount :P
My rides:
True xmod exterior modification aznballa2k4 XMODS Mods and Projects 61 09-04-2005 12:37 AM
Charger modification ENZO ZipZaps Mods and Projects 3 02-27-2005 09:07 PM
MHZ Modification? ZippyZappers ZipZaps 7 02-22-2003 06:29 AM
Dual Cell Modification xatu Bit Char-G Mods and Projects 1 02-10-2003 11:25 PM
Body post Modification DAMZer ABC DTM Parts and Hop-Ups 2 08-25-2002 11:07 AM
