03-16-2004, 11:44 PM
I make great sandwiches
limited slip? no!!
my Rsx is dumb. as it has enough problems as is, the rear left wheel does not spin as fast as the right...WHY? I got blown away yesterday cause of this.... and that would explian why I turn to the right so good. can anyone help me?
My Xmod:
now has Tiny Rc parts and schools everyone here!!!
03-17-2004, 02:35 PM
whats your setup? if you have bearings clean the rear end bearings. while you're at it clean the whole rear end. then try to loosten the wheel nuts and pull the wheel off a little bit. that might help.
03-17-2004, 07:16 PM
thanks aperson. I will try that. Thanks for your help
My Xmod:
03-19-2004, 03:22 AM
just installed AWD and it not slipping as much as before, but the rear A-arms are off alignment...whay is that? is is just my AWD kit?
My Xmod:
03-19-2004, 10:02 AM
if youre using the red a arms they are made f***ed up. put the stock ones back on and that should fix the problem. if there is still no traction on that wheel drive it around for a couple minutes without a body. if you dont have the problem without the body you need to trim the rear mounting tab. just dremel off the little tabs on both sides of the hole where you put the screw through. not on the actual body the black tab.
03-20-2004, 05:59 AM
Thanks again aperson! it comes out that the stock differantial was not doing it's job. I am using the red arms...I will cahnge them back and see what happens.
My Xmod:
03-20-2004, 12:26 PM
I noticed alot of the rear A arms are manufactured incorrectly, causing the rear axle to be angled forward a little bit. When this happens, it doesn't spin as smoothly, and the resulting toe-in condition at the rear makes the car tend to understeer more.
