Old 02-28-2004, 12:28 PM
350z-zz 350z-zz is offline
AWD skyline but a few probs plz help
i just installed the light kit and AWD that my local RS just got in. Everything was going smoothly and i took my time. At the end however when i was putting on the front shocks it seems that the AWD knuckles are not allowing for as much movement in the shocks as in the stock knuckles. im not sure if this is normal but now my front shocks dont flex as much as the back now. It seems that at the place where you screw in the shocks into the knuckle mount, that mount has somehow lowered not allowing as much flexibility. If This is not clear to you, then this is the most simple way to put it, my front shocks are always bottomed out or close to it. So if anyone has some suggestions plz help b/c i rely on my shocks to handle tile with deep divets and therefor the shocks to play a big role for me... thnx in advance
P.S, AWD is pretty dam cool, its helped my turning radius and acceleration alot (i recommend it to anyone with a Xmod)
Old 02-28-2004, 02:24 PM
codedat
350,
Did you check everything? Are the screws in too tight on the shocks, arm, etc..... ? Try loosing the screws then slowly screw them in. Remember not to tight.
Old 02-28-2004, 02:27 PM
RC 2NR RC 2NR is offline
TinyRC XModder
If I understand you...make sure that the whole front assembly is fitting all the way into the chassis. It's very easy to put it in there at an angle when installing it.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-28-2004, 05:50 PM
newbitowner's Avatar
how?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-29-2004, 04:13 PM
2fast4u 2fast4u is offline
Send a message via AIM to 2fast4u
use the stock arms its not the knukles its the arms... its perfectley normal
mini z:ferrari f-40
xmod:body undecided
Old 03-08-2004, 04:30 PM
duwain
ok i think i know what is wrong. when you reinstalled the front knuckles i think you put them in upside down. on the top side of the knuckle there is supposed to be a post will a little dome thing and on the bottom, there is supposed to be just a straight post with no dome think like this,
so alls you have to do is flip them rightside up and switch side, if i am right that is.
Old 03-08-2004, 04:35 PM
striker289's Avatar
striker289 striker289 is offline
Sp33D D3m0n
Send a message via AIM to striker289 Send a message via Yahoo to striker289
yup good job
AWD problem LightFetish XMODS 4 05-04-2006 07:30 AM
AWD questions Lucky7 XMODS 6 09-24-2004 10:46 PM
skyline probs ruslick2g4 XMODS 8 12-06-2003 05:01 PM
2 Many Problems Plz Plz Help!!! Calsonic_racer Bit Char-G / MicroSizers 4 04-25-2003 10:43 AM
Blitz Skyline clone body up for trade(custom lip) Superimport2nr Bit Char-G / MicroSizers 2 01-09-2003 10:26 PM
