Old 02-16-2004, 09:44 PM
bvsciguy bvsciguy is offline
How does a tie rod work?
How does one work and what do the different kinds do?
Thanks,
guy
Old 02-16-2004, 09:55 PM
RC 2NR RC 2NR is offline
TinyRC XModder
A tie rod increases (or decreases) the toe-in of the front wheels. Toe-in is the amount by which the front of a front wheel points inward or outward.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-18-2004, 12:17 PM
aperson's Avatar
aperson aperson is offline
so the only difference btw the 4 is the length?
Old 02-18-2004, 07:02 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Yes. The longer ones create more toe-in, which usually makes your car more stable but less responsive.
Old 02-18-2004, 08:44 PM
TinyRC XModder
Toe-in is a tricky little bugger, if your going to use it, you've got to know what increasing it will do to your car and it's current setup. The problem is that it's a ton of work to put a different tie rod in.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-19-2004, 12:35 PM
aperson's Avatar
in these? only 8-12 screws to take out and maybe a cone gear. not that bad
Old 02-19-2004, 02:34 PM
TinyRC XModder
aperson...I'm not saying it's hard to take it apart, and since you have the AWD you don't think it's a pain to get everything back together?
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-20-2004, 11:36 AM
aperson's Avatar
if you take the knuckles and springs off its not hard at all. the only hard part is the re-assembly with the knuclkes. i have to use a screwdriver to put the axel into the cup.
AWD Diff blocks tie rod?! dj_miracle XMODS Parts and Hop-Ups 2 10-26-2006 04:01 AM
xmod tie rod xxxmod XMODS Parts and Hop-Ups 9 03-01-2005 04:03 PM
what aluminum tie rod xxxmod XMODS Parts and Hop-Ups 2 02-28-2005 08:38 AM
gap between tie rod and servo horn jamgunner XMODS Mods and Projects 3 07-24-2004 03:53 PM
