Old 02-14-2004, 12:27 PM
buzzy buzzy is offline
Steering Trim Issue
Are the steering trim buttons supposed to have any visual effect on the steering when pressing them?
I just got the Acura, and it pulls to the left. I've adjusted the steering horn on the servo but the trim buttons don't have any effect at all.
Should I take it back and get a new one?
Thanks,
Buzzy
Old 02-14-2004, 01:03 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Here is the only way to permanently fix the steering on an XMod. From another thread found here.
Originally posted by Murcielago659
Here's a real quick writeup on it:
DISCLAIMER: If you destroy, mangle, disable, or otherwise damage your XMod, I am not responsible.
1.Take off your rims.
2.Undo the 6 screws on the bottom that hold the steering knuckles
and uprights on.
3.Flip it over and take off the two screws on the back half of the upper deck that hold it on.
4.Remove the upper deck with the steering knuckles, uprights and Upper A-arms still attached to it and set it aside.
5.You should now see the front part of the drive shaft, the tie rod and the white horn on the servo.
6.Undo the screw on the servo that holds the horn on.
7.Now, turn on the car and the controller and wait for the servo to center (less than a second).
8.On the horn which should still be removed at this point, you will see an arrow. Line this arrow up with the little mark on the servo and put the screw back in.
9.Reassemble the front by reversing steps 1-4 above.
I did this to mine last week and I haven't touched the trims since. It's always straight.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-14-2004, 09:31 PM
I'd already tried that.
I took the car back today and got a new one, trim adjustment works fine on it.
Steering Question / Issue Hoverdown3k ZipZaps SE 2 12-14-2006 12:38 PM
steering trim kasper01001 XMODS 11 11-10-2003 12:48 AM
Steering arm issue Darius2250 Bit Char-G / MicroSizers 2 03-25-2003 06:45 PM
