Old 01-26-2004, 08:36 AM
weba2nkill3r weba2nkill3r is offline
teenage r/c maniac
Send a message via AIM to weba2nkill3r
how can i fix this?
i have a lil problem. i was puting my cover on n then it started smoking!this happened to me 2 times . i have a 6 cells on this skyline. this is near the crystal
Old 01-26-2004, 08:10 PM
RC 2NR RC 2NR is offline
TinyRC XModder
The antena must have touched a battery terminal. Unless it still works you need a new resistor...or PCB.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-27-2004, 10:46 AM
teenage r/c maniac
it still works but i have low range on my car . its like a feet away at the most. where do i get this pcb?
Old 01-27-2004, 11:06 AM
TinyRC XModder
Name: PCB ASSY RECEIVER
Part #: 12414207
Price: $9.49
This is from CJ's XMods FAQ
Just go to your local Radio Shack and order it there, or call 1-800-THE-SHACK.
You will have to resolder 4 wires on the new PCB, it might be easier to get a new resistor and resolder it (or have somebody else do it for you).
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-27-2004, 06:46 PM
teenage r/c maniac
soo...........the burned part is a pcb or a resistor?
Old 01-27-2004, 07:54 PM
Actually, its an inductor.
L2 = 0.82uH or 8.2uH (grey red silver) or (grey red gold) respectively
If you can solder, you can fix it without buying an entirely new PCB.
You may want to check out this thread in another forum. Click Me
Old 01-27-2004, 08:27 PM
TinyRC XModder
So, what's the difference?
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-27-2004, 08:31 PM
The hell if I know I'm just using the terminology found in the thread with the fix.
Old 02-08-2004, 09:00 PM
teenage r/c maniac
does this work? instant mesege me [AIM]
Old 02-09-2004, 07:03 AM
TinyRC XModder
It looks like you just threw any inductor or resistor you found, and then soldered it to the wrong side of the board.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-09-2004, 08:15 PM
teenage r/c maniac
sooo.........now wat?i have no experienced wit this thing except soldering
Old 02-09-2004, 08:20 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
look for "Extended Range?" in the XMODS>XMODS section. there is a fix in there. and you have to try it. if you still have bad range try flipping the one you added around.
NEVER UNDERESTIMATE THE POWER
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 01:32 AM
how can you fix scratch windows census007 XMODS Mods and Projects 3 01-26-2004 01:09 PM
How do I Fix This? ugh Bit Char-G / MicroSizers 7 03-05-2003 08:55 PM
How Do I Fix This? ugh Bit Char-G / MicroSizers 4 02-17-2003 07:03 PM
