Old 02-20-2004, 12:49 AM
spinitsidewayz!'s Avatar
boro dori style RC
another lsd idea
working on a new gear diff lsd. ive been trying to get some washers to fit between the side gears and the casing. can never get the gears and plates in there at the same time. and then gotta still work out making some sorta pressure plate.. (_ _) been trying to make an lsd like this. so far ive been through many differential set ups. from paper, to plastic, to metal washers between the gears. problem with the washers being in the middle is the lubricant gets pulled out by spinning outward force and oesnt stay where i want it. im still trying to get a better set up for a 2wd gear lsd. ideas anyone? does the ball diff casing have more space?
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-20-2004, 08:35 AM
RC 2NR RC 2NR is offline
TinyRC XModder
What's wrong with my LSD?
I assume you want to make a diff. that can be used in a RWD setup. Well, good luck.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-20-2004, 07:57 PM
boro dori style RC
theres nothing wrong with ur lsd. i think its great. its just not meant for 2wd aplications.
i found out a way to correct binding problems on these lsd's. the plates arnt binding... its the side gears against the sides of the differential casing. what i did was place a cut disc of aluminum foil and place it in between. it slides smoothly now. lubricant is not nessesarily needed. its the plastic against plastic that causes binding.
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-20-2004, 08:35 PM
boro dori style RC
hmmm the foil between the side gears and the diff. seems to have fixed the problem! i dont know how long it will last but the binding problem is fixed. i also found another material to use as clutch plates. if you take those little circle colored stickers and stick them onto aluminum foil. then punch out holes. you can use the punches to subsitute for washers if you dont have any. just keep the clutches facing paper to foil. you can try using just foil but its too much of a hassle to install because the foil gets messed up. i prefer the washers because they are easier to install and dont require any fabricating.
paper+paper=bind
paper+plastic=bind
plastic+plastic=bind
foil+paper=ok
foil+plastic=ok
foil+foil=ok
r34 - rwd
r34 - awd
dd4 - fwd
Is building a motor out of parts a good idea? Bash_N_Thrash XMODS 4 01-26-2004 01:54 PM
idea for battle feild! Comrade_Boris Combat Digi Q 10 11-02-2003 03:46 PM
Got a little sidetracked. picked up a 2F2F kit today. Revolutionary new idea inside. Clint ZipZaps 19 06-25-2003 02:12 PM
What do you think about this track idea? sneuburg Bit Char-G / MicroSizers 1 09-08-2002 05:30 AM
