Old 01-25-2004, 12:16 AM
97Supra's Avatar
97Supra 97Supra is offline
useful tip
don't you hate it when tou drive around and hit a bump or hit something and one off the batteries comes out just enough to not contact with the holder if you have this problem heres what u got to do
1.get some foam from the x-mod case and some tape or a glue gun for the best results (warm the gun if u plan to use one) some sissors and batery clips
2.cut the foam the size of the battery clip (you can use the back of the clip to get the right measurement).
3.put some glue on the inside of the battery clip and stick the foam over it and do the same with the other clip
4.snap on the clips and never worry about putting ur batteries in again. enjoy
Old 01-25-2004, 09:23 AM
RC 2NR RC 2NR is offline
TinyRC XModder
Thanks for the tip.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-25-2004, 11:07 AM
I Shall Return!
im always having that problem!!! this ownz thnx a bunch
new (to x-mods) speed tip. Increase speed with ANY motor. FREE, no sales pitch! theMonster XMODS 6 03-24-2004 05:42 PM
CHECK IT OUT: Custom exhaust tip godsmistake XMODS Gallery 0 10-22-2003 10:25 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
interesting tip for you drag racers out there hogjowlz Bit Char-G / MicroSizers 3 12-21-2002 03:46 PM
Very helpful tip for those of you... kbtoyz902 Bit Char-G / MicroSizers 4 07-27-2002 11:38 PM
