Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer
Old 10-30-2003, 08:44 AM
yeti yeti is offline
during throttle, car accelerates not straight
Hi there,
my DRR does not take off in a straight line when pulling the throttle. The back of the car shifts to the LEFT side. I think it has something to do with the adjustment of the ball-differential.
I'm driving it on a wooden floor.
During 'steady running' of the car , it does drive in a straight line.
Can somebody help
thankx
Yeti
Europe
The Netherlands
Old 10-30-2003, 03:39 PM
Btman Btman is offline
Your diff may need to be loosened a bit. Try 1-2 turns with a screwdriver to see if that helps. (you can access the diff adjustment screw through the right rear wheel) Another problem you are probably having is that the stock rear tires are a little too hard for your driving surface. Softer rear tires should help. Make sure you change only one thing at a time on the car and make a note of what changes you make. That makes it easier to add or subtract changes you make to the car until its right for you and the track conditions.
Old 11-01-2003, 07:29 PM
Spongebob Spongebob is offline
Try accelerating slower. If you give it full throttle from a stop, it might be losing traction. The stock wheels are not very grippy.
Old 01-31-2004, 08:09 PM
westbitchopers westbitchopers is offline
Send a message via AIM to westbitchopers
a bit off topic, what other tires can be used for more traction?
Old 02-01-2004, 12:28 PM
foam tires. Search for Rocket Racer at horizonhobbies.com
my car wont go straight help me census007 XMODS Mods and Projects 3 12-30-2003 12:35 AM
during throttle, car accelerates not straight yeti Dynamite Rocket Racer Parts and Hop-Ups 3 11-16-2003 12:55 PM
Make UR car go STRAIGHT! scottyboyfun Bit Char-G / MicroSizers 14 02-06-2003 08:31 AM
