Old 10-03-2002, 10:15 PM
catman25 catman25 is offline
do the batt. have to be identical to use them in parrelel?
want a answer before i mess suttin up
Old 10-03-2002, 10:21 PM
ax0n
They should be the same voltage and type if you're going to use them in parallel. The capacity (mAH) doesn't have to match but it's a good idea.
Mixing NiMH 1.2V 120mAH and NiCad 1.2V 120mAH would be bad.
Mixing NiMH 1.2V 100mAH and NiMH 1.2V 135mAH would be okay
Mixing NiMH 1.2V 120mAH and NiMH 2.4V 120mAH would be bad.
Old 10-03-2002, 10:24 PM
i have the 100mah that came with the zip and i have the 120mah that coms from quest for madness..seem ok??
Old 10-03-2002, 10:29 PM
Axel's Avatar
Axel Axel is offline
Send a message via Yahoo to Axel
yup, that's what I'm running... works fine.
-Axel
+Red RX7 ZipZap
-Dual-cell mod (2.4v)
-Antenna mod (100+ feet outside!)
-green ground effect LED ligthts mod
Old 10-10-2002, 12:21 AM
SlackerZ's Avatar
SlackerZ SlackerZ is offline
If I hook two lithium batteries in serial and then hook the duo up to the stock zip battery in parallel could a diode be installed to prevent the charger from energizing the lithium batteries???
Old 10-10-2002, 01:54 PM
Nightwing Nightwing is offline
Bus Driver!
The problem is that the voltage would block the diode-org bat untill the potential of the lithium drop below the drop of the diode and the orginal battery voltage.
I was looking through Jameco and notice they have some nicad stack to get 3v or more. They are around 60maH but two of those would make sense.
Cell phone Batt ctx3201 XMODS 4 12-04-2003 07:28 PM
dual batt mod w/o soldering to car. JTM Bit Char-G Mods and Projects 4 12-31-2002 03:54 PM
batt mod with two 100 mAh nimh battery I2ed Bit Char-G Mods and Projects 0 12-17-2002 10:18 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
