Old 01-14-2004, 08:48 PM
skklown skklown is offline
i wish my xmod could do mad donuts like that!
here in akron ohio its snowin like mad. after jazz band today at about 8 ,my friend took me to go do donuts in his v8 gmc sierra. after we unloaded the bed so there would be no weight we went mad. Wuts a good way to get my RWD skyline to do supermad donuts? i know about using scotch tape but i need sum really grippy front tires otherwise all i get is half donuts. any suggestions
xmod blue civic ricemobile.
Old 01-14-2004, 09:07 PM
charliebrown's Avatar
Grippy front tires?
If your racing on hard, smooth, flat floors, like indoor tiles or hardwood, then use the soft tread tires, found in the rubber tire uprgade kit. Make sur your floor is clean, and here's a quick solution:
take the tires off the wheels and get a bowl of hot water. Let your tires sit in the water for about 30 seconds, then take em out and dry them in a paper towel or regular towel, whatever. Bow drying is not recommended
put them back on, and see how they run. From the hot water, they should be a little softer and give you a grip on the road.
If you're going on the flat concrete, on the tennis court, or outdoors, go for the hard tires. Good luck!
Chuckster...
Old 01-14-2004, 10:00 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
your in jazz band too??? i play piano in my high schools jazz band
in down here in oxford near cinci........mind send a bit of you snow to us? all we have is rain and ice......
-Andres
Old 01-15-2004, 01:21 AM
spinitsidewayz!'s Avatar
boro dori style RC
scotch tape is a good idea. also you should try locking ur diff or just converting it into an lsd then you can pull off doughnuts like nothing. and stick with drift gears.
r34 - rwd
r34 - awd
dd4 - fwd
Old 01-15-2004, 01:46 PM
raytard
i just got a sno day upin ny..... try a vinyl floor like in ur kitchen or sumthin and rty puttin no tire on the rear, or wrappin the tire in a rubberband, andthen scotch tape, so it will be like ( = )instead of | = | so theres less to touvh the ground ^^^ view from tpof tire
Old 01-15-2004, 05:40 PM
well i got my car to do crazy donuts and spinouts. i masking taped the rear wheels and cleaned off the front wheels with a damp cloth. it was awesome
Old 01-15-2004, 05:54 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
try the foam tires in the rear
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-15-2004, 06:11 PM
neurokinetik's Avatar
You mean like this? This car is AWD with soft rubber slicks. The key here is excessive power to the wheels, and a fairly slick surface.
http://users.adelphia.net/~neurokinetik/ras.avi
Old 01-15-2004, 06:33 PM
TypeZer0's Avatar
0reZepyT
lol, omg, that's nuts haha have you tried gunning it straight for like 20 feet than turning hard and make it spin like crazy?
Old 01-16-2004, 10:30 AM
that vid didn't work for me
Old 01-16-2004, 12:32 PM
You need the Divx codec installed to play it.
http://download.divx.com/divx/DivX511Bundle.exe
Old 01-16-2004, 03:59 PM
adiosk8r13 adiosk8r13 is offline
im capital 1"s CE NO!!!
I have a tile floor so if I just put a little bit of water onthe floor I can do insane donuts.
Old 01-16-2004, 04:48 PM
neurokinetik....thats some crazy stuff there on ur video.....is that a gym floor?
Old 01-16-2004, 07:00 PM
Nope, it's a roller rink. I've got more footage, but I need to finish my other video before I can start editing down that stuff.
Old 01-16-2004, 08:57 PM
k
post the longer vid here when its done....cant wait to see it
Xmod Evo Truck HD Dogbone Mod CinnaBun XMODS Mods and Projects 0 02-03-2006 11:07 PM
Mad Large Xmod Lot dietryin For Sale/Trade 11 11-03-2004 06:04 PM
Biggest Fastest REDLINE "BIG BLOCK V-12" ProPulsion Dragster XMOD MOTOR Ever! MicroRCracer XMODS Mods and Projects 25 01-26-2004 04:42 PM
xmod and mini x sawhit4 XMODS Mods and Projects 21 01-25-2004 02:03 PM
Xmod Corvette Project Racer240 XMODS Mods and Projects 6 12-02-2003 09:57 AM
