Old 01-11-2004, 02:53 PM
WhiteSupra43 WhiteSupra43 is offline
"Umm I need a new car"
Send a message via AIM to WhiteSupra43 Send a message via Yahoo to WhiteSupra43
Left Cup JOINT???
my lefft rear wheel is wobbling sum one said its the left joint cup or sumting can any help me how to fix it im me at AustinSwish08 on aim or post
Old 01-11-2004, 04:51 PM
adiosk8r13 adiosk8r13 is offline
im capital 1"s CE NO!!!
the same thing ihas happened to me and i have no idea whats wrong with it
if you have ever stared into a can of
orange juice because it said concentrate you might be a redneck...
Old 01-12-2004, 02:14 PM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
mine wasnt wobbling at all an it just fell out
Old 01-12-2004, 08:30 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
all you need is to find some washers that'll fit on the axle. put them between the wheel and bushing/bearing and that should stop it. just dont tighten the nut too tight.
NEVER UNDERESTIMATE THE POWER
Old 01-13-2004, 09:02 PM
its not working
Old 01-14-2004, 08:40 AM
aperson's Avatar
how many washers and how thick were they. they have to fit almost perfectly on the axle or you will still have a wobbly wheel
Old 01-14-2004, 12:35 PM
cj1267's Avatar
cj1267 cj1267 is offline
CJ's Hobbies.net
Send a message via ICQ to cj1267 Send a message via Yahoo to cj1267
Mine did that as well. Washers didn't work for me either. After closer inspection of the wheel I found that the D shaped hole was rounding and very little of the D remained. Changing the rims solved my problem. Inspect to hole and look for damage.
New joint cup on vette jaubery XMODS 5 03-01-2005 07:40 PM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 01:32 AM
left cup joints xmod456 XMODS 12 08-11-2004 09:11 PM
Wanted: Xmod left joint cups...AWD kit...light kit newbitowner For Sale/Trade 1 02-04-2004 12:11 AM
Left Joint Cup kelleyiscool XMODS 7 01-02-2004 01:24 PM
