Old 01-05-2004, 05:33 PM
93Supra0wner 93Supra0wner is offline
Question Diff. problems after 5 Cell
well i finished my 5 cell yesterday using a few new ideas i had......its super fast except that when i floor it ANYWHERE going ANY SPEED instead of tires spinning or just blasting off my differential spins without tires moving or anything......my tires dont spin no matter what.....i have the red differential for the REAR that came with the AWD (not the awd one but the one told to install once awd is in even thought i took my awd out)I dont care if i do a semi burn out or not...its just that i get the feeling im loosing some juice from this thing spinning and stuff/.
Old 01-05-2004, 07:20 PM
Joey's Avatar
Joey Joey is offline
Are your differential screws tight enough in the rear?
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-05-2004, 07:21 PM
ooo ya definatly i tightened them
Old 01-06-2004, 06:23 PM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
do what I do just lock your diff. improves drifting ability and acceleration, plus it dosent hurt top speed like awd
Old 01-06-2004, 08:37 PM
ya ive been thinking of locking it but how? i dont want to glue it as of it being permanent.....
Old 01-06-2004, 08:43 PM
DNF RIDER #4 DNF RIDER #4 is offline
gust put the stock diff in. its spider type so there is no slipag i have the all wheel drive and i had the same problem this will make you exelerate faster and in your case spin the tires
did some one call my name
Old 01-07-2004, 05:04 PM
NissanGTR01 NissanGTR01 is offline
Send a message via AIM to NissanGTR01 Send a message via Yahoo to NissanGTR01
if you remove your all wheel drive then you have to change the diff because it does slip it is a limeted slip i had the same problem what i did was took out the limeted slip out of the rear which made the car act like it was front wheel drive and i put the original diff in the rear and left the awd front diff in this combo equates to all power to the ground no frt weel burnout and no rear weel spin no burn out what so ever the powere is divided 50/50 mmmm acceleration
Nissan Racing
KA24E
7500 RPM
280 HP
270FT-lbs
HELP!!! diff problems raytard XMODS 8 01-19-2004 07:32 PM
Dual Cell problems Zephyranthes Bit Char-G / MicroSizers 0 03-30-2003 11:08 PM
