01-02-2004, 06:47 PM
Sup Dude
6 Cell MOD
I have a 5 Cell mod in my XMOD already, im wondering if the 6 Cell Mod would fry the curcuit board or damage the motor or somthing?!?
By the way, I have a Game Maker Website
www.gamemakerworld.homestead.com
01-02-2004, 06:48 PM
Got Brains?
no. need more proof? stft
This is your brain.....
01-02-2004, 06:50 PM
Sup Dude
Yes,
By the way i have a Game Maker Website.
Its: www.gamemakerworld.homestead.com
01-02-2004, 07:20 PM
Got Brains?
tripleplay
please don't post if you don't know what you're talking about. if you stft (Search the Frickin' Threads) then you'll see that MOSt people here are running 6 cells.
01-03-2004, 08:25 AM
Sup Dude
I installed the 6 Cell and the motor started to get VERY hot.
I guess im sticking with 5 Cells!
01-03-2004, 10:59 PM
should I use a AAA or AA?
Does it have to be the same brand?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
01-04-2004, 12:21 AM
what is the advantage with 5-6 cell?
01-04-2004, 08:53 AM
Sup Dude
you should use AAA.
THey dont have to be the same brand but i HIGHLY recomened it..!..
The advantage you will have with 5 or 6 cells is that your XMOD WILL HAVE as much as 40% more horsepower and torque..!..
01-04-2004, 11:19 AM
I would recommend 5 cells with IC-3's. That will give you 7.25 volts through the system, That will give you over 50% more power (both Horsepower and torque!)
Chuckster...
01-04-2004, 11:32 AM
Sup Dude
Yeah
Becuz
The RS rechargeable batts are 1.2 volts each.
The Regular Batts are 1.5 volts each.
I would recommend 5 Cells with Regular Batts.
I would recommned 6 Cells with RS rechargeable Batts.
6 Cell Mods make the motor VERY hot tho.
01-04-2004, 12:08 PM
0reZepyT
regular alkalines may have a hgher voltage but it won't put out as much current as nimh or nicd. run your car with 4 alkalines then run it with 4 nimh, you'll see a big difference
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
01-04-2004, 02:12 PM
Sup Dude
i no ive tried it
01-05-2004, 12:47 AM
IC3's made my car faster than duracells.
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
01-05-2004, 01:05 AM
Li-Ion Addict
I've run 2-cell Li-Ion packs (rated at 3.6v per cell, 7.2v total, but higher at max charge) in both of my xmods for a while now with no problems. Just be nice to it and give it time to cool down between runs. It seems the electronics can handle the extra voltage, but the motor will probably die much faster. Good thing they're pretty cheap!
AAs would work just as well as AAAs if you can get 6 of them to FIT inside the xmod chassis (good luck!).
And yeah, I'd go NiMH or NiCD for the 6-cell mod just to be safe. Even these will read at 1.4v or more at full charge with no load.
pbmax
01-08-2004, 08:17 PM
Actually, some guy on "the other site" calculated that the alkalines from RadioShack have around 1350 mah, only in the triple AAA's!
Chuckster...
