Old 01-03-2004, 12:33 PM
scatmanjohn01 scatmanjohn01 is offline
quick Question?
Well, i fried my supras electronics (battery touched antenna) anyways, i was wondering what i would have to replace all together inside the xmod to get it running at full range again? if anyone has a spair xmods electronics (in working condition) tell me the price hehe.
Old 01-03-2004, 01:12 PM
ax0n
I fried mine, by forgetting to turn the car off before a motor swap, the driveshaft shorted out the circuitboard. you can call 1-800-The-Shack (1-800-843-7422) and order this part (found in the XMODS FAQ, Thanks cj!):
12414207 - PCB ASSY RECEIVER $9.49
It's a pain in the boot to get out.
1) Make sure the car's off and Remove the batteries
2) Remove the car's receiver crystal.
3) Take off the rear deck like you're doing a motor swap. Don't forget to disconnect the antenna.
4) Disconnect and set aside the drive motor.
5) Remove the rear motor bell bracket (yellow piece)
6) Slide the battery holders back and pull them outward to remove them from the body.
7) Remove the top cover for the front suspension.
8) Remove the 2 screws nearest the on-off switch on the underside of the chassis.
9) Remove the Screw that was covered by the front suspension cover, near where the Crystal socket is. It attaches the black cover to the yellow bracket that the driveshaft goes through. be careful not to lose the bushing that's in there.
10) Remove the screw at the back of the steering servo.
At this point you should be able to remove the entire electronic guts from the xmods chassis. It consists of the PCB, battery holders, steering servo, and connector that jumps to the drive motor, all connected together with wires. There is a plastic switch that slides into the PCB. It can come loose, so don't lose it. Under the PCB, there is a piece of red thin cardboard, almost like construction paper, insulating the PCB from the metal heatsink. Under the paper, there's a metal tray (heatsink) that the whole radio/servo assembly is nestled into. There is heat transfer grease between 2 chips on the PCB that mates them to the heatsink. I'm inclined to believe those 2 chips are the stock FETS, but I am unsure.
I swapped radio/servo gear between 2 cars, so I don't know what that part looks like when you order it from radioshack directly. You may need to solder some parts onto it. Hopefully at the very least, it comes complete with the antenna wire, battery holders, steering servo, and drive motor connector all attached from the factory. With luck, it will also come ready to drop-in, with a new paper insulator and heatsink. If it doesn't come with a new heatsink, then you'll want to CAREFULLY clean the goo off the heatsink, then use a dab (*small* dab, like half the size of a stock XMODS lug nut) of heatsink paste (lithium grease, Arctic silver, etc) in the middle of each of the 2 chips before putting the reciever back in. If the new PCB doesn't have the plastic switch part, move it over from the old PCB, and make sure it's in the correct position before putting everything back together. Don't forget to put the paper insulator piece between the PCB and heatsink, or you'll fry it even worse when you turn it back on!
best of luck!
Old 01-03-2004, 01:41 PM
ax0n
I just called them, and asked her to describe the part to me (pull up a photo or diagram. she says it's a PC board with a black cover and some wires coming out of it. so I think you might need to do some soldering, bro.
Old 01-03-2004, 02:07 PM
i dont really need a new servo, but mainly just where the antenna wire hooks into...
So, if i do order this PC boarcd with black cover and wires coming out of it, what would i be ordering lol?
Old 01-03-2004, 02:51 PM
ax0n
That's it. It's the Receiver/Electronic Speed Control board. If you need mirrors or body parts you might as well order all that at the same time, too. Check the FAQ for more part numbers.
Old 01-03-2004, 06:40 PM
aperson's Avatar
aperson aperson is offline
the board that has wires coming out of it is the Light Kit. i fried mine too along with the servo. i ordered them both and should be coming in on monday or tuesday. I dont think they come assembled. the 2 pcb boards that are included in the reciever assembly should be soldered together already. ill know when i get them.
Quick painting question Yaksha XMODS Gallery 2 01-08-2004 04:21 PM
a quick question Comrade_Boris 1:1 Scale Cars 10 01-05-2004 06:02 AM
Quick Question Riven Bit Char-G / MicroSizers 6 12-23-2002 03:05 AM
quick newbie question bojangs Bit Char-G / MicroSizers 2 10-06-2002 12:44 AM
