Old 06-07-2007, 03:02 PM
rydzjunior rydzjunior is offline
xmod ball bearing used to make ball bearing motor!!!!!!!!
I added an xmod ball bearing at the end of the motor. I took out the little metal bushing in back, drilled a hole thats a bit smaller than a ball bearing where the metal bushing was. Then i added tape around the motor shaft at the end enough to fit perfectly the ball bearings hole. then I closed the motor and the ball bearing went into the hole that I drilled replacing the metal bushing. Have fun. Everything was placed on a gen1 xmod using a stage 2, 9 teeth motor.
[IMG]
And this is my aluminum wheel. How do u like it.
Old 07-13-2007, 06:01 PM
McgJosh McgJosh is offline
Tape doesn't seem very reliable.
How is the performance?
Old 07-18-2007, 09:41 PM
the tape is very sticky and reliable. its the tape use to block heat or smoke to come out of fireplaces and stuff. its aluminium tape. costs a lot but very very sticky. the tape can withstand great heat. the performance is better. i just made it to the front can too. the motor turns smoother and makes less noise from vibration.
Report on Motor Swap in MS Pro..... DarkTari Bit Char-G / MicroSizers 7 03-26-2003 08:45 PM
Motor Support Sub-Forum - Read This First! tinyrc TinyRC.com Motor Support 0 03-16-2003 08:38 PM
ne1 no how to make all the power go to the motor? isk8blind Bit Char-G / MicroSizers 2 01-19-2003 05:20 PM
is it any good to make a beeper motor my car XgamerX Bit Char-G Mods and Projects 1 11-30-2002 02:58 AM
