12-14-2002, 10:29 PM
BitOnline GM
Serious Problems!!!!
Hey guys i just got my bit, it is a tomy and everything, a white skyline on 27. Ok i opend it up and the range blew nuts so i undid the knot under the board and it still didnt help, i tried to do the pot thing also but it didnt help one bit. What should i do, im very scared.
12-14-2002, 10:30 PM
What It Is To Burn!
this is normal!!! try redoing the antenna with either cat5 cable or a solid copper cable about 6-8 inches long.
So Tell Me, What's The Price To Pay For Glory?
Bit Char-G Fairlady Z 57Mhz (2-Speed), 3.5 or 3.8, 150mAh NiMH, Blue Gears
MicroSizer RX7 27Mhz (Originally a 27Mhz Celica) (Injured Reserve)
ZipZap Supra (Originally a 49Mhz 911), DKS 2.8, 150 mAh NiMH, Red Gears
12-14-2002, 10:31 PM
Microman to the rescue!!!
You can try the Cat5 mod or the Telescope antenna on your controller. I think that those would help, you probably already know this but you can check out www.questformadness.com
**EDIT**
My bad, didnt know aero posted already, must of right before i did
12-14-2002, 10:38 PM
BitOnline GM
Where can you get cat5 cable?
12-14-2002, 10:40 PM
What It Is To Burn!
home depot, radio shack or a local computer store.........its also category 5 network or ethernet cable or CAT5....
12-14-2002, 10:42 PM
BitOnline GM
so you use that huge cable or do you strip it and take a wire out of it?
12-14-2002, 10:45 PM
What It Is To Burn!
strip it and there are 8 wires inside, just pick one. you can also double them up for increased range, but it adds extra weight to the back of the bit.........are you good at soldering???
12-14-2002, 11:08 PM
BitOnline GM
Yes i am decent
12-14-2002, 11:09 PM
BitOnline GM
Although should that work?, and i adjusted the pot alot i think.
12-15-2002, 03:57 AM
Assembling a CLONE army..
Is it Cat5e? 2$+1$shipping=3$ for a small scrap of cat 5e?? What a bargin!! Perhaps its solid gold wire...
RIP
