12-29-2003, 10:17 PM
Drift withit
my car wont go straight help me
my car wont go straight. i know the first thing you are going to tell me is use the buttons on the controler.... i tried it still pulls to the left is the any thing else i can do to fix my piece of ****
A man that has made no mistake, has made nothing at all, and i have made alot.
White Supra
awd
C-logic kit
Stage 2 Motor Kit
Body Kit
Spin Brush
12-29-2003, 10:43 PM
addin onto that ?, when i do use the button to set it straight then shut thew car off, it return to the stock setting, is there a way to keep it how u set it so u dont have to do it every time u turn the car on?
12-29-2003, 10:54 PM
well you could just reset the steering servo arm thing that comes out of the front of the electronics part of the car. alls you gotta do is unscrew the little white thing that attatches to the tie rod, and make the little lines line up, screw it back on, and you shouldnt have to keep reseting the steering trims. BTW i read this on another thread.
12-30-2003, 12:35 AM
Got 4.2 King? I do : )
yep reseting the arm works. after you turn on the car and the transmitter (with the arm off) just line up the line on the arm with the line on the chassie and it will drive strait when you turn on your car
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
