Old 12-24-2003, 07:12 PM
c89zx7r c89zx7r is offline
Send a message via AIM to c89zx7r
slot car motors
someone should also try a aftermarket slot car motor . very powerfull and some have adjustable endbells for timing adjustments . motors are sold buy . parma , drc, mura , fastones ,
trinaty , . try a s16c or a group 20 by mura . very fast .
Speed Kills Drive a Honda .
87 Conquest TSI for life
Old 12-25-2003, 03:52 PM
3series takumi's Avatar
mini-eX-Driver
the only problem you will run into there is that slot car motors done run off of low volt batteries. they need wall juice, and lots of it.
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 12-25-2003, 06:22 PM
R33E8 R33E8 is offline
Yah, and they usally are about 10-20 turn motors they have in there. Which would blow your esc.
Xmods Civic:
Old 12-26-2003, 05:43 PM
Evomod
Would it blow your ESC with a FET upgrade?
Old 12-26-2003, 05:48 PM
mini-eX-Driver
chances are even with a fet upgrade it wont move very fast. you have to understand that those motors need alot of power, power that 4 or 6 batteries wont supply. if you have one, look at how thick the wires are around the arm. just my 2 cents though
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 12-27-2003, 07:39 AM
red02zx3 red02zx3 is offline
I actually tried this one....once I got the parma motor outta the slot car, I noticed its WAY too big.....needs some serious modification.
Old 12-27-2003, 09:26 AM
casper975 casper975 is offline
They will work if you can get them to fit because the BRP cars come stock with a 16d motor in them, but they are ran off of 12volts on the slot car tracks, so you would probably need to use 5 or 6 cells
I dont know how well they will work with 4 cells
IF SPEED KILLS I WOULD BE DEAD BY NOW
Old 12-27-2003, 09:33 AM
I dont see how it would fit without major modification. And then, you would need ALOT of power to it unless there is some converter on the slot car track that converts to power. I dont see how that little motor is able to run straight off the wall juice. I once plugged a 1/10 scale motor directly to the wall in my house and let me just say .......FIRE!
Old 12-27-2003, 09:40 AM
My buddy owned a slot car shop and I worked there for him he used a 12volt battery that you use in your 1 scale car or truck and he had 2 of them he would use one one day and charge the other one for the next day as for a xmod I dont have one but I do have a mini-z overland and yes you would have to do a lot of work to make a 1/24 scale slot motor fit, I put a custom built group 20 motor and 6 1800mah AA's in a old BRP fun wons and it was a bat out of hell and real hard to drive,
Old 12-27-2003, 10:03 AM
that sounds awesome! Id just like to get this car movin a little faster. Im working on a spinbrush motor right now and on some paint for my skyline. I always have some crazy thing going on with me and my toys! Im thinking about trying to put a micro servo, ESC and reciever in the Xmod. I found a micro ESC that can handle 20 amps! Then I could dump a huge motor in her.
Old 12-27-2003, 09:56 PM
hotrod29728's Avatar
i have a hand wound group 12 kelly motor i would like to put in my xmod i paid 50 bucks because i was hoping it would work but now im not so sure .... please help me ....
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 12-28-2003, 06:45 AM
do you know what the current draw is on the motor? Or the number of turns?
Old 12-29-2003, 12:43 PM
Evomod
This is the response I got from Parmapse about using these motors in Mini RC cars
"The problem is the Slotcar motors run in the opposite direction so they will
not work. The Armature will not work either."
Old 12-29-2003, 04:23 PM
Thats why you take the motor apart and reverse the magnets or just hook them up backwards THEY WILL WORK if you can get them to fit,
Old 12-29-2003, 04:25 PM
mini-eX-Driver
what about that
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Initial D is addictive zombiebaby Bit Char-G / MicroSizers 96 07-20-2003 01:31 AM
slot car mod! Spanky Bit Char-G / MicroSizers 29 06-10-2003 05:15 PM
will 1/24 slot car parts work ? catman25 Mini-X Parts and Hop-Ups 3 01-30-2003 07:54 PM
Mounting two motors connected to same gear?? Def Bit Char-G Mods and Projects 11 01-03-2003 09:37 AM
slot car motor? BMW325 Bit Char-G Mods and Projects 6 11-11-2002 01:43 PM
