Old 01-01-2004, 09:08 AM
Mr BigShot Mr BigShot is offline
TinyRC PRO Modder
Goals for 2004 Xmodders
I wanna here some Goals for 2004 !!
Mine So Far - 1. Put an even bigger motor in then I have "pic's in Mr BigShot's must see upgrade's " . 380 can i think it is . 2. Get ,make ,fab, beg RS , somehow get alloy parts for my dogbone joints ,and knuckles. 3. make at least one of my 6 cars have a CF or alluiminum frame . Hopefully i can just buy one . 4. New bodys of course 5. Finally"i sure there will be more" But be able to go to the local mini z track and wipe some butt on the track .
Old 01-01-2004, 09:47 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
My goal is to get this to fit under an Xmod body.(with all the Hobby grade electronics on it)
then make center shaft bearing holders(out of CF or aluminum)
an adjustable motor mount
wheel hubs to allow XS wheels to slip over them
axles(dogbones/U-joint)
find/gather up a complete screw set for the Xmod(maybe RS has them now)
attempt double front/rear A-arm setup
make an off road Xmod (soon - like next)
Not an all together complete list but that's most of it.
Make a screaming fast reliable Xmod(or resemblance of one) that will blow by most every mini-z (gonna be real tough but it's a fun goal)
Old 01-01-2004, 10:35 AM
Joey's Avatar
Joey Joey is offline
Not wreck and break the thing.
I think that's a good place to start.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-01-2004, 10:37 AM
I Shall Return!
ive set up a to do list with 5 stages for project blitzkreig
-stage 1...
costum paint job
custom wheels
functioning roof scoop
custom exhaust the lights up
fog lights
spinner rims
non functioning disk brakes
neons
-stage 2...
stretch suspension springs
stabilizer bars
stiffen ball differential but not lock
mechanicly center steering
oil moving parts
aluminum skidplate
bearing upgrade
turbo switch on controller
polish heatsink
-stage 3...
carbon fiber driveshaft
alloy drive components
180 size motor, rewond retimed and 12Tpinion (custom)
6 cell upgrade
high grip tires
alloy gears
battery heat sinks
-stage 4...
steering resistor upgrade
external fet mod
lipoly batts
light weight chassis
custom paint chassis/ components
10V cap
-stage 5...
show those miniZ's who their messing with!
if you have any other ideas that arent too expensive (like the novak shipset) or too outrageous (like a 2spd transmission). i am currently in the middle of my paint job which will prolly take until next weekend to finish, pix soon! i know theirs a alot listed but i plan to have project blitz kreig complete by march to begin racing, i will also make a thread for pics and information on my car (have that up when paints done) btw sry bout your accident mrbigshot g.w.s.
Old 01-01-2004, 11:17 AM
Evomod
Question
Sluggbug ,
Do you have any CAD drawings of your CF Chassie? Could have a look at them?
That CF Chassie is sweet
Old 01-01-2004, 12:14 PM
I KNOW NOTHING!!!
LOL Why yes I do have many CAD drawings of that chassis set up and many drawings of other idea's and configurations.
Why would you want those drawings? there's nothing in them that everyone else couldnt draw.(if they take the time)
If I just give out the drawings then anyone could just make it or atleast save A LOT of time.(cant do that sorry)
I'm sorry but it is bad enough that I even post a picture of it, I wont dare just give out drawings that I have weeks into but since it looks to be fragile I might not make this chassis.(needs to be tested)
Old 01-01-2004, 12:20 PM
93Supra0wner 93Supra0wner is offline
Slugbugg, after you come up with a final revision/design of your CF chassis, will you be selling them?
Old 01-01-2004, 12:27 PM
I KNOW NOTHING!!!
yes most diffenently but I want a good product first and it takes a lot longer than I had hoped.
Those upper/lower CF pieces I cut weigh as much as just the lower stock Xmod chassis but my chassis looks fragile and I still cant get all the hobby grade electronics stuffed under an Xmod body.
Oh well I'm still working on it.
Old 01-01-2004, 08:23 PM
neurokinetik's Avatar
Just make sure 180 motors still fit...
That looks great, BTW. First I've seen of the CF version.
Old 01-01-2004, 08:42 PM
BlaZin_Ns's Avatar
BlaZin_Ns BlaZin_Ns is offline
Import Racer
Thatz one good looking chassis
02 Rsx
Old 01-01-2004, 09:48 PM
I KNOW NOTHING!!!
180 yeah most likely but I'm thinking an adjustable motor mount that I can screw or clamp a 45T too.
The 180 will most likely end up being the best overall choice since it fits much better.
Thanks BlaZin_Ns
Old 01-02-2004, 01:41 PM
micro kid's Avatar
Do you getto dremel?
my goal is to build the sweet body kit i designed for my supra. i wish i had a scanner so i could attatch the drawings. if it does get done it will have big side scoops on the front air dam (for the fake turbos) and a bigger fron grill made of mesh. BMW style turbo vents will take their rightfull place on the fenders ill use the wild body kit hood. stock side skirts roof scoop big fake cf and aluminum wing. the back will be a smoothed from the bottom of the taillights down with two skinny oval air diffusers under the license plate and have two big fart cans our the sides of the back air dam behind the rear wheels.
Old 01-02-2004, 11:06 PM
Rx7NoZ's Avatar
Rx7NoZ Rx7NoZ is offline
wow ur good
Xmod:
Civic (black)
Stiff Suspension
Awd
White side skirts,White Carbon fiber hood,White rims and Drop
Old 01-02-2004, 11:07 PM
Rx7NoZ's Avatar
but the bad thing is i would neverrrrrrrrrr be able to do that unless u put the steps with pics and what kind of aluminum was that????
Xmod:
Civic (black)
Stiff Suspension
Awd
Old 01-03-2004, 08:31 PM
JDMDrifter's Avatar
JDMDrifter JDMDrifter is offline
Send a message via AIM to JDMDrifter
My goal is to have a Nomuken-style Skyline down to the smaller details, a very good drifting setup, and enough money to get my S13 Coupe and modify it(not likely).
Have you drifted your R/C lately?
-XMod Skyline GT-R
-Yokomo MR-4TCSD Drifter, SS5800 powered, 180SX, Chaser, Stratus, Skyline, RX-8, and a few other bodies
-Yokomo GT-4 RTR, too much to list
-Savage 21, O.S. .21RG-X w/Nova Head, custom center skidplate
Any Long Island, NY Xmodders? xodus XMODS 0 01-25-2004 12:51 AM
Michigan Xmodders Race Club RacerDeX XMODS 3 12-18-2003 03:38 PM
MONEY MAKING Xmodders The FAD tenchu XMODS 1 12-15-2003 06:27 PM
