01-01-2004, 02:37 PM
Stage 3 of my xmod
Stage 3 of my work, pure speed! My fet's are mounted on the motor heat sink. The blue can you see is the 10,000uf power Cap. Mounted on each side is 2 CR2 lithium batteries
LithiumXmod
Mods:
4 Cell CR2's Photo Lithium Batteries
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Suspension - Front: S Rear: H
Steering - 1.5 degree Tie Bar
Coming soon:
Ball Bearings
01-01-2004, 03:16 PM
Be careful of that... You can't have the tabs of all four transistors attached to a metal heatsink without using some kind of insulator. Otherwise you'll short out the motor output, possibly taking the FETs out in the process.
01-01-2004, 03:36 PM
xmod destroyer
that's pretty cool it looks like a big pile of batterys and wire
350z-SS 130 motor, bearings cf driveshaft, custom paint,
supra- high torque 180, 6 cell bearings,
civic- powerdash, bearings,cf driveshaft
rsx-fried
4supras fried
2 skylines detroyed
1 civic destroyee
01-01-2004, 03:56 PM
superglue doesn't conduct eletricty, unless im wrong?
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
01-01-2004, 04:09 PM
So what did you do? Glue to plastic casing of the transistors to the heatsink? It's hard to see in the pic.
01-01-2004, 04:13 PM
I glued the fins of the heat sink to the motor heat sink, the car runs fine. If something was wrong, my batteries would have heated up really bad and give off a smell. neurokinetik, do you happen to aim?
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
01-01-2004, 04:20 PM
True, but it still seems risky to me. I would have used an ohmmeter or continuity tester to make sure that the transistors are truly isolated. The other problem is, over time, that setup is going to be exposed to vibration. Sooner or later, the transistors are going to be conducting across that heatsink. When that happens, it won't be good.
No I don't use any form of IM...
01-22-2004, 04:47 PM
I Shall Return!
whats dose a power cap do?? and whats the highest cap that i can put on
01-22-2004, 07:30 PM
whats the huge capictor for, and whre does it connect to etc?
01-23-2004, 12:39 PM
That's some crazy stuff! Where'd ya get ur fets and what type are they?
