12-27-2003, 08:44 PM
Rayovac Ic-3's! Whats The Matter?!
i just got IC-3's! i charged them utnill the light went off and my car only lasted 10 minutes then it dramatically dropped to where my younger brother who can only crawl beat it. is this cuz its the first time?! what is this!? are they really gonna only las thtis long!? TEN MINUTES? ok
XModS Gloss white Toyota Supra
SII drag motor
Wild style body kit with custom spoiler
Rayovac AAA IC-3 rechargables!
Eibach stiff and soft suspension
Tire Uprgrade
command lites
What is the Matrix?
12-27-2003, 09:02 PM
They should last much much longer than that. I get a good 30 minutes out of mine running the higher end motors. I would stick them back in, as with NiMH, you don't have to discharge before recharging. Maybe the charger is false peaking so to speak. You might have a faulty charger.
12-27-2003, 11:59 PM
Li-Ion Addict
How long did it take to charge them initially? How quick is the charger supposed to charge them? My charger false-peaks fairly often with NiMHs. I've found that after a few charges / discharges it finally figures it out.
pbmax
12-28-2003, 07:21 AM
My initial charge and every charge after that has been right at 15 minutes as it is supposed to. So far, my charges and run times have been pretty consistent.
12-28-2003, 02:16 PM
Go Banana!
yes mine have been extremely consistant as well, i'd get some different batteries to see if it's a bad charger or if there's something wrong with the batteries.
12-28-2003, 07:48 PM
I just got one today too. I got the one that can charge 2 at a time.
It's working perfectly. (knock on wood)
Should I use the car until the batteries die before storing?
12-28-2003, 08:05 PM
possible they are not I-C3 cells you got? Rayovac does make numorous other cells... and chargers.
12-28-2003, 08:08 PM
You shouldn't have to, NiMH batteries are not supposed to develop a memory like NiCad batteries. I hardly ever run my car for the entire capacity of the batteries, and when I come back, they are still good to go for the rest.
If you are going to be storing your car for a long while, I would at least remove the batteries from the car and transmitter.
12-29-2003, 02:15 AM
mini-eX-Driver
i hear though it you plan you store the batteries for a long time of not being uses, you should leave them with a little charge. got that info from blindbatts
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
12-29-2003, 10:46 AM
Anymore ideas?
12-31-2003, 12:11 AM
well if your car has uneeded friction, hair in axle, bad bushings/bearings.. or whatever it will drain them much much faster...
have you charged them again yet?
You do have both the 15 minute cells AND the 15 minute charger yes?
12-31-2003, 12:06 PM
yah i have both batt's and charger i tried rechargin them and now theyy run fine!
SII drag motor
Tire Uprgrade
command lites
What is the Matrix?
01-01-2004, 10:49 AM
I thought it was the other way around! i thaught the hydride had to be fully discharged and developed memory and cadnium it didnt matter, thats why all the beginner cars use cadnium, u cant screw it up. li-ion is still best tho in my oppinion. this would really suck for me if nicad had the memory cuz i would have like 20 screwed over batteries sittin in my race box
01-01-2004, 11:41 AM
RC Tinkerer
Ni-Mh batteries are mure resistant to the memory effect, however every so often you should drain them compleatly. As for storing them, it does not matter wether you store them full, 1/2 charge, or empty, Ni-Mh will not get damaged if they loose a charge. I know that if Gell Cell batteries (Like in wheel chairs) loose all power, they will not take a charge. They require a charge to be left in them in order for them to recharge properly. If you charge them whenever you are not using them they will last for years!
01-19-2004, 05:27 AM
You never want to fully discharge any rechargeable battery. The best way to discharge to a safe level is to run the car until it cannot roll with the weight of the chassis. Then recharge. And yes NiMh can develop memory, it is just more resistant to than NiCads.
