Old 12-05-2003, 03:14 PM
Shiporu's Avatar
Shiporu Shiporu is offline
I make great sandwiches
Unhappy Lights Problem....
I got two Blue LED's that I hooked up to my car. First I had it hooked up to the motor. It worked good but, just before top speed , the lights would go out. How can I make it stay on when I hit the trigger?
This morning, I tried to splice them into the command lights, but it did not go on. Am doing something wrong? Can anyone help me?
Thanks...
My Xmod:
Old 12-05-2003, 06:04 PM
moose moose is offline
Bad Company did that mod serch for it
Old 12-05-2003, 06:08 PM
funkytones funkytones is offline
was the car on at the time? was the remote on? were the LEDS wired in there correctly? batterys charged? could be a few things...
Old 12-05-2003, 07:30 PM
xc/zz
Why blue leds? With a zz se it comes w/ headlights that you can simply paint blue!
Old 12-05-2003, 08:13 PM
Shiporu's Avatar
Everything was off. fresh batteries. Thanks for the replies everyone. Now the problem is that the blue LED's don't glow brightly, just dim.... even after looking and following Bc's tutorial, it still is dim...
xc/zz, the lights are going to be put in the bumper.
My Xmod:
Old 12-05-2003, 08:35 PM
blues need more voltage or somthing... because of the color it produces... same with some other colrs... some LEDs power up with less voltage... like reds... the whites take a little more... and blues are more yet...
Old 12-06-2003, 02:02 AM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
you burned the led's. trust me, i've done it a couple of times. i bought two different yellow led's. i gave it about 2 volts and it looked amber. in my past experience hihg quality led's can usually exceed their max rated voltage (a blue 5mm led from RS rated for about 4-5 volts is running off 12 volts in my computer for the past 2 years) so i went to a bit over 2 volts and they shut off. giving it 2 volts made it very dim. btw, i never got yellow light from either led's, they were always amber
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-26-2003, 02:53 PM
teamdeadbunny's Avatar
teamdeadbunny teamdeadbunny is offline
Track Master
This may be a moot point but, if you want a coloured light... why not just cut a small piece of stage light gels out and poke into the light holes up front, then use the RS light kit to make it glow?
RX-8 with lights. Widsinator ZipZaps Monster Truck 1 11-15-2004 01:41 AM
command logic lights problem kasper01001 XMODS 10 12-18-2003 09:51 PM
glow lights on car SkylineEvo XMODS Mods and Projects 0 11-12-2003 12:48 AM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
