I plan on that.
Here is more stupidity from RS! They thank me for my asshole reply (yes I am trying to limit my cursing)! lol!
Hello Again,
Thank you for your response.
The ZipZaps have a 90-day warranty. If the unit is failing to hold a
charge and after cleaning the unit, does not steer correctly, then we
suggest that you return the unit to the store for warranty replacement
if purchased within the past 90-days.
When responding please ensure that the ORIGINAL EMAIL IS INCLUDED,
either by using the REPLY option or cutting and pasting it in. Failure
to do so, may cause a delay in responding.
Cookie
Radio Shack Product Support
http://www.radioshack.com
http://www.radioshack.com/Coupons/Coupons.asp
-----Original Message-----
From: Kenny Houseal [mailto:kennyhouseal@hotmail.com]
Sent: Friday, December 19, 2003 3:18 PM
To: RS Store POS Mail user
Subject: RE: Problem-cjw
That helped neither of my problems! The car drives straight but turns
harder
to the right than the left. It will not charge at all. It used to work
fine
but it all of a sudden died after sitting for about a month. I am pretty
disapointed with the quality of these cars so far. They steer much
better
right than left and it now doesn't charge. That is two strikes and with
three I will never buy from your stores again!
>From: "RS Store POS Mail user" <RS.Store.POS.Mail.User@tandy.com>
>To: <kennyhouseal@hotmail.com>
>Date: Fri, 19 Dec 2003 15:08:18 -0600
>Hello Kenny,
>Thank you for your email.
>We suggest that you try adjusting the steering
>Steering Trim
>If your car does not drive straight when you release the steering
wheel,
>adjust ST TRIM on top of the controller.
>Place the vehicle on a block or turn it over so the tires do not touch
>the ground. Turn the transmitter and vehicle on, and press L or R ST
>TRIM until the tires point directly forward. When you finish,opearting
>the car, turn off the vehicle and controller. (NOTE: ST TRIM will
>revert to factory settings when the controller has been turned off.)
>We have received information from our customers concerning increasing
>the charge time. The customer turned the car upside down and ran the
>motor until the battery was dead, recharged it, and repeated this three
>times
>If the car still fails to steer correctly, we suggest that you return
>the unit to the store where it was purchased.
>Cookie
>Sent: Thursday, December 18, 2003 4:58 PM
>To: ZipZaps Webmaster
>Subject: Problem
>I am experiencing trouble with my Zip Zaps SE. I try to charge it and
>nothing happens at all. Both the car and controller are on and I
>followed
>the suggestions on your website. I also have problems with the
steering.
>There is very uneven steering. The car steers much better to the right
>than
>the left. I would like to find out what the problem is. I hope you can
>help.
