Old 12-21-2003, 11:53 PM
kasper01001's Avatar
("\(0.o)/") Rawr!
AWD turning
anybody got an answer about awd turning? because mine turns tighter lefts and wider rights, the servo is centerd and the tierod is stock. I also left the stock diff in rear. so wat can it be? this is really bothering me because last time I had a 4.5 tierod and it would make wide left and VERY wide rights. PLZ!!!PLZ!!! HELP!!!
Xmod Parts Help
Old 12-21-2003, 11:57 PM
Martlet21 Martlet21 is offline
Send a message via AIM to Martlet21
The same thing happens with mine (until my tire mod), but I don't mind. I only got AWD so I could run it in my garage. The floor is so slick that 2WD spun out if the accelrerator was down half way.
My Tiny R/C:
XMODS Yellow Skyline GT-R
AWD
Jumbo Tires
Stock everything else
Old 12-22-2003, 11:44 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
thats why i got the AWD kit Martlet21. i see that you have ball bearings, take the front end apart and clean everything in the front end that might help a bit. also try cleaning and then greasing the front differential. also do the same thing with the rear end.
NEVER UNDERESTIMATE THE POWER
Old 12-22-2003, 11:49 AM
("\(0.o)/") Rawr!
does anybody else have the same problem?
O yea its out of topic but, has anybody tried putting the stock dif in the front and the red dif (I think its called theLSD) in rear?
Xmod Parts Help
Old 12-22-2003, 12:00 PM
aperson's Avatar
the front red gear diff is the same as the stock white one. and as for the gear in the front and LSD in the rear. it works great. thats what i used for drifting until i fried my electronics.
Old 12-22-2003, 12:28 PM
Queso's Avatar
Queso Queso is offline
tiny rc racer
first thngs first
take the lsd diff and throw it in the trash
next put the other diff in
and then it should work fine
"If I had a bike it would have mad pedals"
Old 12-22-2003, 07:35 PM
duwain
i had the same problem but i replaced the red suspension arms with the stock yellow ones and then i worked fine. or maybe thats not what really fixed it and im just an idiot.
Old 12-22-2003, 07:40 PM
("\(0.o)/") Rawr!
should I do that? I already left the rear A arms to stock
Xmod Parts Help
Old 12-22-2003, 07:45 PM
Mr BigShot Mr BigShot is offline
TinyRC PRO Modder
LOL Just wait to you start upgrading
You think your having problems now just wait ! You know those crapy little plastic axel's and u joint's pretty much all the drive train for the car sucks !Why cause it is plastic and it break's !!!!
Old 12-23-2003, 02:22 AM
lowam lowam is offline
what i have noticed is that if you put the ball diff int the front and the limited slip in the back it handles alot better. it gives the rear wheels less of a chance to spin out because its not as ''locked' as the ball diff. so in other words just switch the front and rear. its helped me.
''if you want to feel funky. feel free!but please dont get that funk on me.''
Old 12-23-2003, 02:46 AM
("\(0.o)/") Rawr!
So..Will that help the turnning?
Xmod Parts Help
Old 12-23-2003, 08:18 PM
("\(0.o)/") Rawr!
Help anybody?
Xmod Parts Help
Old 12-24-2003, 04:54 PM
("\(0.o)/") Rawr!
ok my next problem is that when I turn to the right (the wide turn), it goes faster, but with left its apposite
Xmod Parts Help
AWD with Resistor Mod for steering cool_cars XMODS Mods and Projects 20 12-04-2004 04:10 AM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 02:32 AM
AWD questions Lucky7 XMODS 6 09-24-2004 11:46 PM
AWD skyline but a few probs plz help 350z-zz XMODS Parts and Hop-Ups 6 03-08-2004 05:35 PM
Non front wheel turning or front wheel turning? bvsciguy Digi Q 0 09-13-2003 11:05 AM
