Old 12-21-2003, 09:56 PM
xodus xodus is offline
XmodSource Dot Com
How Do you make Motors?neurokinetik? or BC?
Hi..i was wondering if someone can post some links for ALL the parts needed to make a motor..and maybe and/or a tutorial? If you know the parts, please list the names of the parts..thanks..
i put "..neurokinetik? or BC?" in the topic name b/c neurokinetik and BC, you seem to know the most..
Old 12-22-2003, 07:19 AM
neurokinetik's Avatar
Old 12-22-2003, 09:50 AM
XmodSource Dot Com
Thanks..but...
Thanks..but do you know what gauge wire i gotta use for these motors?? Thanks
Old 12-22-2003, 10:00 AM
From my own experience, 28 gauge or 30 gauge seems to be the way to go, at least in 130 motors.
Old 12-22-2003, 10:13 AM
XmodSource Dot Com
o..and
o ok..umm one more question..heh
what are the things on the motor, capacitors? Do i NEED them? if so, and idea where (Model #?) Thanks..
Old 12-22-2003, 10:18 AM
XmodSource Dot Com
o damn..
O..damn..uhh forgot to ask these ones..
the armature are like the lil plate things, correct? Is there a certin # of them u need? (I saw 37T and 38T) What does 37T,38T mean? and last question (for now)..what is the main shaft in the motor called (axle?)?
Thanks
Old 12-22-2003, 04:52 PM
geofroley's Avatar
R34 Skyline is God
37T and 38T are the number of teeth on the pinion gear, if one is included.
My Bit: Phast motor (Orange)
Old 12-22-2003, 06:36 PM
Bad Company's Avatar
neurokinetik knows a lot more than I do about motors, I'm a body man.
Some people like what's on the inside, I go for what's on the outside......cuz I'm shallow like that.
Old 12-22-2003, 06:38 PM
XmodSource Dot Com
ha, thats good..im def trying to learn the inside for now..one day i'll do what u can..hopfully..well i hope neurokinetik or someone who knows what im asking, can post some answers soon. Thanks..
Old 12-24-2003, 04:07 PM
red02zx3 red02zx3 is offline
37T and 38T are the turns of the motor. The lower the number the higher the RPMs the motor turns. 30-34 guage wire should be good to wind the motor with. Stronger magnets are better for torque and not so good for top RPMs, same hold true for wire thickness. Search around and youll see what the stock winds on the spinbrush, stage 1 and stage 2 motors are. Its a good baseline. Dont go too low on the winds, youll burn out the FETs.
Old 12-24-2003, 05:23 PM
XmodSource Dot Com
wow..thanks alot for all that info..also..so its 38T..do is that the minimum i must do for it to work? thanks..
Old 12-26-2003, 06:00 AM
No, Im not sure what the minimum is, Neurokinetik would know.(Maybe)The lower the winds, the more current draw, the higher the chance you will burn out your FETs. The stage 1 motor is like 89 turns or something like that .....the spinbrush is 70(?) and the Stage 2 is 49. Im building a 40 turn , with the spinbrush motor....look around, Im going to post results soon.
Make your own composite sheets. bizzybody Bit Char-G Mods and Projects 0 04-05-2007 05:15 AM
i have some cool ideas for zz help me make it work guitarplaya3000 ZipZaps Mods and Projects 4 12-23-2005 04:34 PM
if I could make you ANYTHING out of plastic.. ?? Draconious XMODS Parts and Hop-Ups 22 04-07-2004 05:31 PM
