Old 12-02-2003, 12:45 PM
SkylineGT-R_man SkylineGT-R_man is offline
Angry Help! Skyline not working right
My Skyline isn't working right at all. It works good when I have the controller right next to it. When it goes maybe three to four feet away, it starts to stutter. Like this ...!...!...!(the ! means it gets a little bit of power). when it goes a little farther yet, the power completely cuts out. This is my second Skyline, the first did the same exact thing. When the second would work long range, it would get smoked by my friend's less invested and less powerful Supra. All the mods I have done to it are: Stage 1 & 2, suspension & steering, tires, metal bearing kit, and rechargable batteries. My friend's Supra doesn't have Stage 1, metal bearings, and sus. & st. Their are rumors on the recall on all Skylines, is this true? If it is will they take mine back and give me a new revised Skyline even though mine has some "battle scars"? Or, will they just give me a different Xmod? If so, will they take my body kit and Skyline starter kit without a receipt? If anybody that reads this thread that has information, please e-mail me any info. Thanks.
Old 12-02-2003, 03:35 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
first, before you take it back, check all the wires. on the motor, batteries, antenna, etc. then check for debri in the gears. then check the batteries. if everything is ok, then return it. you should be able to because you can only get xmods at rs and they know how much they cost. if they give you crap then either go to another store or raise hell. and make sure you take all you mods off.
Old 12-03-2003, 05:38 AM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
hmmmm....make sure the tx and rx crystals are in all the way........
-Andres
Old 12-04-2003, 04:00 PM
Patriot13 Patriot13 is offline
I had the same problem with my Skyline. It would cut in and out at a certain point on the track almost like it was out of range. (Recently my friend started having a similar problem with his Supra. ) Other times it wouldn't respond at all until I right on top of the car.???? The problem kind of went away though, so I just assumed it was battery related. (I removed and replaced all the batteries.)
rsx to skyline VaTifosi XMODS Parts and Hop-Ups 1 11-27-2003 01:29 AM
skyline for me Comrade_Boris XMODS 14 11-05-2003 05:21 AM
Toben's Skyline! :D tobenjunk Bit Char-G / MicroSizers 6 04-08-2003 07:54 PM
Blitz Skyline clone body up for trade(custom lip) Superimport2nr Bit Char-G / MicroSizers 2 01-09-2003 10:26 PM
Digi Q SKyline rnt working RCGuy978 Digi Q 1 12-27-2002 12:09 AM
