Old 12-01-2003, 09:00 PM
Alex's Avatar
Alex Alex is offline
sex: Yes please!
Send a message via AIM to Alex
Turning issues
when i turn right i have a wide turn and when i turn left i have a tight turn....why? i also noticed that when you turn the controller on and turn the wheels they dont turn to there full potential. use your hands to turn the wheels and youll see they go much farther...
Old 12-01-2003, 09:39 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
try adjusting your steering trim. that should help.
Old 12-01-2003, 10:29 PM
jaubery jaubery is offline
Steering trim is to correct straight line tracking. If your car is constantly pulling to one side or the other you can adjust the steering trim to compensate.
To solve your problem 1) Check for debri in the wheels and knuckles. 2) Are your batteries fully charged? That's the first thing to go when your batteries are low. 3) Check to make sure your controller is set on max st. range. 4) Grab the wheels with the car turned off and fully turn them a few times. This will help loosen up stiff knuckles.
turning radius rob3662 SuperSlicks 0 12-08-2004 04:54 PM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 01:32 AM
Turning right too wide ovo XMODS 3 11-10-2003 05:18 PM
Non front wheel turning or front wheel turning? bvsciguy Digi Q 0 09-13-2003 10:05 AM
