Old 11-30-2003, 08:01 PM
viperkilla's Avatar
Antennea?
Have you guys noticed that the antennea that is on the chassis is very fragile and breaks easily? Has anyone broken their antennea and soldered it to the little piece of metal? If so how hard was it and does it still have the same amount of range before it broke?
Old 11-30-2003, 08:04 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
did you break yours?
Old 11-30-2003, 08:32 PM
security civic security civic is offline
sleeper mall civic
Send a message via AIM to security civic
how did u break it , i got tired of the studering so i took the stock antena off and put on a longer one (over 100ft in range)
douglascounty!!!
Old 11-30-2003, 08:35 PM
jco jco is offline
i think i have broken that connection on every xmod i have
as for how hard it is to reconnect... not hard at all ,just solder it back to the tab
reconnecting imo has not made the range any better or worse
btw...are u talkin bout the actual antenna or u talkin bout the wire and tab from the pcb? cause im talkin bout the wire and tab
never jump in the water...use a ladder
Old 11-30-2003, 08:52 PM
yz85rider yz85rider is offline
the wire from the tab on my 2 x-modss both fell off so i soldered them on.
Old 12-01-2003, 08:25 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
if the wire falls off, make sure that it doesnt touch the motor or it will fry a resistor and your range will be really screwed up.
NEVER UNDERESTIMATE THE POWER
Old 12-01-2003, 10:07 AM
jco jco is offline
....as it says in the owner's manual- get into the habit of removing the batteries from the car when not in use
and if it falls off when running and touches something (motor, batts,ect....ya then your screwed
Old 12-01-2003, 03:14 PM
i didnt know that. thanks for that bit of info.
Old 12-01-2003, 03:20 PM
viperkilla's Avatar
I am talking about the wire and tab. I haven't broken it yet, but I have on my Skyline XMOD.
Old 12-01-2003, 03:23 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
if you breack it then souder it back and put hot glue on the sauter and part of the wire. this will help keep it on better. make sure not to put hot glue in the hole!
--Chris
Aka...aero528
Old 12-01-2003, 05:26 PM
thanks for the info. RS really needs to get better solder or something.
Old 12-01-2003, 05:28 PM
sleeper mall civic
they need stronger wire and where u dont have to remove the battery pack to change out something
douglascounty!!!
Antenna help lckyrocket XMODS Mods and Projects 3 12-30-2003 12:33 PM
smoking civic kasper01001 XMODS 13 12-20-2003 08:13 AM
