11-18-2003, 04:03 PM
like my dog??
traction tips
i know this is kinda weird, but do you guys have any good tips for increasing traction without buying awd? i am running on lonlium and i keep slideing out. driving tips would be helpful too.
--Chris
Aka...aero528
11-18-2003, 04:08 PM
Redneck Drifter
soften the tires by soaking them in WD40 for a while
11-18-2003, 04:10 PM
like my dog??
k sounds kinda different. for how long? what corn feild by the way do you live in, because we have alot around here?
--Chris
Aka...aero528
11-18-2003, 04:18 PM
Re: traction tips
You should try the tire upgrade kit to increase traction.
11-18-2003, 04:29 PM
bitPimp
Get the tire upgrade kit and put the soft tires on the rear. Leave the medium stock tires on the front and see how that goes. I race on a fairly slick surface, and I hve to mop the hell out of it to remove any dust. I usually get a crappy towel really damp (like get it wet and wring it out) and then wrap it around the head of a pushbroom. Cleaning the floor makes a bigger difference than the tires, but the soft tires in the tire upgrade do work.
11-18-2003, 04:32 PM
like my dog??
ok, the floor is pretty dirty so that could help. the next upgrad i am going to get is the awd so i am not going to ge the tires. what if i just soak the rear tires in wd40? does that realy make a big difference ?
--Chris
Aka...aero528
11-18-2003, 04:43 PM
Redneck Drifter
overnight
i live in west Kentucky
11-18-2003, 05:05 PM
0reZepyT
soften the rear suspension by one step, it may help
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
11-18-2003, 06:58 PM
like my dog??
ok sounds good.
--Chris
Aka...aero528
11-19-2003, 08:35 AM
try spraying them with a little bit of Prestone Brake Cleaner. that makes a big difference
11-19-2003, 10:35 AM
swiffer sweeper!
I use one before every run. You'd be amazed how much dust and hair is still there after sweeping with a normal broom.
also try the soft treaded tires
11-19-2003, 10:59 AM
Got Cheese?
Amen to that!
Instead of WD-40, Brake Cleaner, or anything else, try Sunscreen! (Seriously!)
You might want to look at grooved or patterened tyres , as opposed to slicks, especially if your surface is naturally dusty/hard to clean. I know there are lots available for the Mini-Z & Mini-x, so I presume you can try these on your xmod....
Lisa: And vice versa...
11-19-2003, 12:44 PM
I like what the soft treaded tires do for my car, but in sharp turns, the tires literally come off the rims and then jam up in the wheel well. I may have to go with the hards, which are less malleable and won't peel off the rims in sharp turns.
11-19-2003, 03:00 PM
like my dog??
ok i will try some of the ideas. thanks alot guys.
--Chris
Aka...aero528
11-19-2003, 03:05 PM
By, the way what type of dog do you have?
