Old 11-12-2003, 06:57 PM
targatop7mgte targatop7mgte is offline
Send a message via AIM to targatop7mgte
need some assistance
okay i've been diong the basic upgrades to my xmod (everything you can buy at RS) well yesterday i went out to test drive it again and if it gets more then 5 feet away it looses reception its really annoying i used to be able to go from one end of a basketball court to the other now i can't go more then 5 feet. the wire w/ the metal plate that scrwed to the antenna broke off. it was then that the problem started i stripped the end of the wire and wrapped it around the antenna. w/ same results. i then soddered it back to the plate same thing. i then switched EVERYTHING(i mean everything i stripped it down including the crystal) from my car to my buddies Skyline. it worked fine for sometime but still had a little shorter range but not enough to worry about. then the wire broke again, same problem resodered same problem. ANY HELP PLEASE I"M SORRY FOR THE LONG POST. these things are so kewl but this is sooo annoying.
Old 11-12-2003, 07:51 PM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
didnt read it all way too long but did you try changing the batterys
Old 11-12-2003, 08:12 PM
v0lc0m85 v0lc0m85 is offline
Send a message via AIM to v0lc0m85
happened to me. i had my skyline for like 2 days, then i got awd and stage 2 and once i got it all on the range went to like 5 feet. i too tried everything and gave up. took everything off and made it stock again, and then returned it. got a new one, slapped the stage 2 and awd back on and it works.
Old 11-12-2003, 09:23 PM
umm... yeah.
and i can't return it had it for to long. but the thing is this is the 2nd one thats done that. could it be my crystal or something?
Old 11-12-2003, 09:35 PM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
Could be the crystals, try new ones. Could be that you fried the receiver when you did your solder job too. If you left your iron on the receiver wire too long this may have ocurred. If the crystals do not work take a look at the electronics and see if anything looks out of whack.
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-13-2003, 04:04 PM
colin4371 colin4371 is offline
PPG Co-Owner
the black wire that connects to the antenna most likely broke loose, try lookin at that.
Old 11-13-2003, 04:08 PM
Originally posted by colin4371
the wire w/ the metal plate that scrwed to the antenna broke off. .
Old 11-14-2003, 04:34 PM
dragon4450's Avatar
customanix
something you might want to do is go out and get some really good wire and replace the crap wire they use in the xmod. i plan on doing this this weekend.
Servo Assistance rssjib XMODS Parts and Hop-Ups 1 07-14-2004 07:50 AM
Assistance with LED MOD please help a newbie SmokenRubber Bit Char-G / MicroSizers 0 12-04-2002 04:02 AM
