11-13-2003, 03:35 PM
Mini Rc Enthusiast
Bc Help ...
Hey BC , I finally broke down and bought an XMOD today .
Very impressive . I am having a problem turning left .
Standing still I can turn right with no problem , but when I
try to turn left it stutters . What can I do to correct ??
11-13-2003, 06:00 PM
I really couldn't tell you too much, I haven't experienced that problem yet. If you have already adjusted the trim on the controller, I would say the next step would be to re-set the servo horn. You can find instructions in the link in my sig.
Hope this helps.....anyone else have any other suggestions?
If it is stuttering, there may be a problem with the electronics.
11-13-2003, 06:36 PM
Mini Rc Enthusiast
Thanks ,.. I'm working on a custom body to mount on it .
Trying to find alternative battery placement .
11-13-2003, 07:26 PM
I had to sand down several parts on my xmod because I noticed they were rubbing together causing uneeded resistance. I'd take the front top plastic cover off and watch as you turn the wheels both directions looking for what is binding you up. Do you have AWD installed yet? Today I noticed that the steering bar that is connected to the steering servo was rubbing against my front differential and also rubbing against other stuff too! and I was not able to turn both directions. I took the steering bar out and dremeled it down a little skinner(not much) and then oiled it up when I reinstalled. Steering works again, and smoother then before.
