Old 11-12-2003, 05:22 PM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
Send a message via AIM to EMX
Sanding Question
I've decided to re-paint my xmod since i ****ed it up, what grit sand paper should i use to sand off the paint i painted with?
thanks
Ian.
Old 11-14-2003, 01:49 AM
martin3103's Avatar
martin3103 martin3103 is offline
Send a message via Yahoo to martin3103
Thumbs up
I would use the highest grit I could find. 1000 +
Martin
Old 11-14-2003, 04:27 PM
dragon4450's Avatar
customanix
to sand off the old paint i would use something like 100 ir 150. the to clean up the plastic i would use 400. also use 400 on the primer coats. then use 800 on the paint coats and 1500 on the clear.
Old 11-14-2003, 05:02 PM
rct_19903 rct_19903 is offline
are you sanding of the stock paint? if so you may need something more like a belt sander . they arent painted stock. they are colored plastic. so you will have to reduce your car to a pile off shavings before you get through the paint. just wipe it with a little laquar(sp) thinner and then prime and paint.
Old 11-15-2003, 01:23 AM
dragon4450's Avatar
customanix
they arnt painted stock? then i wonder why my yellow skyline is white on the inside......... did they paint the inside white then?
Is this normal? (newbie question) WSPFreak ZipZaps SE 12 12-29-2004 12:38 AM
Nero, question about Gold.... codedat XMODS Parts and Hop-Ups 0 04-30-2004 03:55 PM
Tab lowering enfini + question at the end tobenjunk ZipZaps SE 7 04-06-2004 08:42 AM
Wheel axle question! MythosGR Bit Char-G / MicroSizers 1 01-26-2003 08:31 PM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-25-2002 11:32 PM
