Old 07-10-2003, 05:48 PM
faulkbeets's Avatar
faulkbeets faulkbeets is offline
not so bright
Send a message via AIM to faulkbeets
engine and gear test results
today i did a test on which was best and i figured that the yellow zipzap motor with green or red gears are best for speed but not handling
deace out
Old 07-10-2003, 05:57 PM
civic freak's Avatar
Tiny RC Guru
i beg to differ
not 2 b mean but i beg to differ the fastest setup is Nos. Ex. with teal (fast) Microsizer transfer gear with the red Zip Zap axel once again not to be mean wouldnt wont to be on your bad side or nething
Old 07-10-2003, 06:02 PM
faulkbeets's Avatar
not so bright
lol i dont see what could be mean about it but i shouldve cleaned my nos motor better before running it in the test cause it still had some hairs...which i guess made it slower, thank you
deace out
Old 07-11-2003, 03:17 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
the nos xpress motor is pretty fast, but the king 4.2 is faster
but if speed is all you want, do the mosfet mod on just the forward h-bridge
Old 07-11-2003, 05:49 PM
strider_mt2k
Re: i beg to differ
Were you aware that they are exactly the same thing?
Both the MS teal and the ZZ red are 8.25:1 ratios.
My fastest has been with the purple motor and the 8.25:1 gearset. It's generally the gearset i use on everything except dual cells. i use 9.86:1 on those for more control.
Old 07-11-2003, 05:53 PM
NatakuARN's Avatar
NatakuARN NatakuARN is offline
Anime RPG Nut
What is Mosfet
Old 07-11-2003, 06:06 PM
faulkbeets's Avatar
not so bright
info here http://www.bitpimps.lixlink.com/page...opic.php?t=798
deace out
Old 07-11-2003, 08:13 PM
Tiny RC Guru
i beg to differ
they are not tha same strider_mt2k tha teal meshes togetther better i agree its tha same # of teeth but it meshes together better like i said earlier, not to mean be i hate people to be mad at me
Old 07-11-2003, 09:03 PM
dr1zz's Avatar
thoeretically they are the same gear ratio and all, and i find that certain clone gears mesh better with the ms pinion gear
but who cares, if you got no handles, then go straight all you want
Old 07-11-2003, 09:54 PM
strider_mt2k
All I use are the black 6 tooth pinions that MS seems to put in every accessory kit. Well, that's not true, strictly, as I use the Zip Zap too.
I haven't seen much diff, but I'l try mixing them up to see.
It is an interesting idea. I suppose I could look at them side by side under a microscope at work too. Not that I'm an expert.
Actually the assumption that they are made idetically, or by the same company was all mine!
Old 11-15-2003, 10:55 AM
tngrt
It's Nitrous Express, not NOS Express. Nitrous Oxide Systems (NOS) and Nitrous Express (NX) are competing companies both selling nitrous oxide.
Newbies!: Level two engine upgrade. food123 XMODS Parts and Hop-Ups 3 12-29-2003 09:53 AM
Best Engine for my car buddha ZipZaps 3 05-10-2003 10:18 AM
Three Special editions, 2 Microsizers and some engine work. AceQ Bit Char-G / MicroSizers 3 10-23-2002 09:42 PM
Purchased 4 knock offs, 1 Microsizer on 5 freqs / results. AceQ Bit Char-G / MicroSizers 1 10-14-2002 11:49 PM
Prb with 3.0 engine Seb123 Bit Char-G Parts and Hop-Ups 1 09-12-2002 01:31 PM
