Old 10-29-2003, 09:46 AM
corysmith's Avatar
corysmith corysmith is offline
Fred Obando Rox My Sox
Send a message via AIM to corysmith
HELP, and i will give you a dollar!
IDK whats up with my xmod, i was just running it and it started this, i took it all apart and cleaned it, then it still did it, pls help!
http://66.207.2.168/My%20Pictures\car\car.avi
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
Yellow Front, Blue Rear Springs,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
All at a 30% Discount, OORAH!
Old 10-29-2003, 09:53 AM
Queso's Avatar
Queso Queso is offline
tiny rc racer
it kinda sounds like your driveshaft is binding
try lubing the driveshaft bushings at both ends
where's my dollar !!!!!!!
"If I had a bike it would have mad pedals"
Old 10-29-2003, 09:55 AM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
Send a message via AIM to EMX
wow
that does not sound good
sounds like something is rubbing some where, but with out being there i couldnt tell you where. where is the sound comming from?
did you run into something?
is an axel rubbing?
also it could be a bearing.
Old 10-29-2003, 10:01 AM
corysmith's Avatar
Lubeless driveshaft it was, oh wise one, if u really want that dollar. i suppose i could, lol
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
Old 10-29-2003, 10:07 AM
corysmith's Avatar
double or nothing on my range problem, i think its the 9v, how long do those typically last?
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
Old 10-29-2003, 11:25 AM
Fusion Fusion is offline
Send a message via AIM to Fusion
1st off do you know where the sound is comming from?
If not then you need to start buy applying a small amount grease to the gears if you have not already done that. You should also check to make sure you replaced the yellow plastic bushings on the rear suspension arms off of the stock rear arms (the red rear suspension arms dont come with them). If those were transfered I would next lube the axles. If you car still makes the sound you final step would be to lube the drive shaft. I think that just about covers it. Let us know what happens and if anything I posted here helped.
Fusion
ps. Dont worry about the buck if what I said works.
Old 10-29-2003, 11:30 AM
OPPS
I didnt read all of the posts Im glad you got you xmod working correctly.
Old 10-29-2003, 11:31 AM
corysmith's Avatar
Originally posted by Fusion
OPPS
No problem my man
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
