10-23-2003, 02:12 AM
all this talk about mosfets and 'fets'...
so what are they really? and, by upgrading them, what can i achieve?
10-23-2003, 02:23 AM
I have a beach ball...
Do a search in one of the bit forums or the zipzap forums. Basically they replace the transistors on the PCB with MOSFETs that have lower internal resistance. Less resistance means more current gets to the motor and it goes faster.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
10-23-2003, 03:03 AM
how involved is this, meaning can i do it myself, with a soldering gun, or what?
10-23-2003, 09:48 AM
so I re-wired it
Actually if you look up mini z fets you will find a lot more about them, and what they do. Basically it's a switch that can limit the amount of current going thru it. As you get a better one, or more of them, it's easier to pass the current thru in a controlled way.
It really comes into play when you have a motor that demands a lot of power, and it "pulls" current thru the fet and heats it up. There are motors you can get that will fit these things that will pull 2 amps!
That's why you would want to upgrade- it'll keep the circuts from litterally burning up.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
10-23-2003, 06:17 PM
Bad Driver
Unfortunately, It looks as though there is not enough room on the PCB for more. I'm gonna try and make an external turbo from Radio Shack MOSFETS  . Should work pretty well.
10-23-2003, 09:24 PM
Got Mini-z?
or you can do an external...
10-24-2003, 10:45 AM
so I re-wired it
mini z turbo?
Have you guys looked at the mini z turbos? There are about 4 or 5 companys that make them, and they may work- Most cost from $12 to $25 and they are supposed to plug in on the mini z's- not bad for something that already exists, and may just plug in.
how much different can it be?
anyone messed with one?
Famous last words:
10-24-2003, 07:49 PM
external turbo
tried it ,it is not working need possible solutions ??????here is the color code red and black wire ,battery case,white and blue wire pcb board ,white positive, green and yellow wire motor....
steering works after wiring,turns left and right off the controler but throttle not working ,checked all the wires,......solutions ?????
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
reverse fets
f150monster |
ZipZaps Monster Truck |
0 |
03-27-2006 11:05 PM |
mosfets
chinkst3r |
XMODS Mods and Projects |
1 |
07-20-2004 10:02 AM |
Using non logic level fets
bob256 |
3 |
02-06-2004 07:01 PM |
stacking Mosfets
aperson |
XMODS |
0 |
12-16-2003 12:54 PM |
