10-21-2003, 05:08 PM
BROKEn
When i was doing the steering upgrade i took the whole front of the cra aprt and now i can not get it back together. If you have the answer please e-mail me at thecoopie@aol.com Subject XMODS.
Thanks
10-21-2003, 05:18 PM
Well cant you just use the directions to figure how to put the car back together?
10-21-2003, 05:22 PM
NO
IOt is not in the directions
10-21-2003, 05:42 PM
I have a beach ball...
umm, what exactly are you having problems with?
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
10-21-2003, 05:43 PM
I KNOW NOTHING!!!
Its not that hard.
start by finding the directions then carefully lay the parts out roughly how they go.
Once you have the parts layed out close you will start to see how it all goes together.
tierod has to be installed before uprights.(the uprights are labeled R / L)
suspension arms have to be properly attached to the uprights before attaching uprights to chassis.
that black axle spacer has to be properly postioned through the uprights before attaching second upright.The steel shaft is to the left of the little finger on this if you are looking straight down at the car with the back facing you.
The steering knuckles/spindles go on only one way, there is a left and right(not labeled).the pin coming up from the tierod end goes through the slotted hole. on the spindle, the long pivot pin (kingpin)goes down and the ball shaft goes up.make sure you have the steel axles and bearings/bushings installed.
dont worry about shocks untill last but make sure the a-arms are right early on so you will be able to attach shocks.
10-21-2003, 09:34 PM
AHAHAHA im sorry... thats friggin funny. u could always buy another one and use it as an instruction model
I am the insider, i kno all
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
pcb cover broken?
frizzen |
ZipZaps Monster Truck |
4 |
07-18-2005 03:55 AM |
Broken rear tab
dje7447 |
Bit Char-G / MicroSizers |
2 |
01-07-2004 10:19 PM |
Help with broken car...
skyline0276 |
Bit Char-G Parts and Hop-Ups |
4 |
11-09-2002 11:48 AM |
broken bit
xsboost94 |
2 |
10-01-2002 10:13 AM |
Broken chassis
BaliLover |
7 |
07-15-2002 12:40 AM |
