Old 09-06-2003, 11:41 PM
vtheo's Avatar
vtheo vtheo is offline
Monoaural.
Propo for Cheap! ZZSE
i have read some threads on this forum, it seems like you guys need some cheap small propo parts. Take a look at the thread in the zz forum, called 'zipzaps se are here!' they are propo, and only $25.
Keep on trucking!
Vanilla The Ostrich
Old 09-07-2003, 06:16 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
I had thought about this to, it seems like it would help alot of people get into the 1/87 scale trucks. (I know I would like to)
I wonder if the ZZ-se setup will have the same control as the ones used in these trucks now.Not all proportional controls are the same, some are much smoother (more steps) than others.
Old 09-11-2003, 10:30 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
they could potentially be a time and money saver for tttt projects. i guess not tenough information is known yet
Old 09-15-2003, 10:57 PM
vtheo's Avatar
Monoaural.
well i hear that steering is 8-12 steps, not the greatest. and speed is more, i dont have one yet but i wanted to tell you guys. it uses rack and pinion, with(i think) 7mm motor. another thing is that they are lacking touque with the fast motors, but you guys dont need speed hehe, and there is always mosfets. seems like they packed as much as they could under the shell, they also have headlights and taillights which turn on with forward/reverse i was figuring that you could wire up the headlights leads with the moter, for a small boost, if it would work
J-On
Old 09-20-2003, 01:57 PM
BabyKiller's Avatar
no theres like 5 steps in steering and 6 steps in the forward motion and 5 steps and reverse motion i own 2
+ (4.8v)
Old 09-21-2003, 10:21 AM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
I have one and the steering has so much torque that when I turn full to either side I can't move the wheels without breaking it or making it skip gears!
Old 09-21-2003, 10:59 AM
I KNOW NOTHING!!!
I havnt tested either of my ZZse's out thoroughly yet, but do you think they will be able to turn two 26mm dia. x 18mm wide tires? how about all four?
I'm just curious, no real reason for asking.......it's not as if I'm working on a little monster truck or anything.......yeah thats it.........just curious, thats my story.lol
Old 09-22-2003, 05:22 AM
Itan Itan is offline
Send a message via ICQ to Itan Send a message via AIM to Itan
you mean something like this?
(plz note i did this at 4 in the morning so my spelling might not be right and the picture might be off or even a little confusing)
the "rack" part of the rack and pinion has to be free moving so for the wheels to turn
Engeneer to be
Old 09-22-2003, 04:01 PM
I KNOW NOTHING!!!
Well sort of like that, no wait just picture a micro(palm sized) TXT and you will have a close idea of what I'm trying to make.
I have the 4 spindles/knuckles made and I have the axle gears pretty much set I just need to finish drawing up the axle halves and cut them.Once all that is done I can work on the easy stuff.
Old 09-22-2003, 06:03 PM
Yeah I got a ZZ SE and was horribly disappointed so I think I’ll rip it apart and make my car in my picture
Old 10-20-2003, 06:08 PM
Racer9's Avatar
Tiny RC Pro
Yeah it should quite easily be able to turn the tires. and maybe all four if you are moving. At a standstill it depends on your traction.
Steering again, this time its encoder bias resistors and uneven propo cyborgzero ZipZaps SE 14 02-03-2004 02:12 PM
4.8 Volt ZZSE urbanavenger ZipZaps SE 2 10-03-2003 11:13 AM
Did some comparisons between ZZSE / Bit Clones today... ax0n ZipZaps SE 9 09-30-2003 05:27 PM
Propo Special Codes as of January 18 keal Digi Q 8 07-02-2003 11:49 AM
Propo Special controller: May be safe to use NiMHs keal Digi Q 9 01-23-2003 07:10 PM
