Old 10-25-2003, 04:00 PM
Smurf Smurf is offline
Lube Master
Send a message via AIM to Smurf
Help with my laymans tricell
My tricell works.... well kind of. It charges then it goes but it goes rather slow and it runs outa batteries right away. Any ideas why this is happening?
http://www.halffull.net/phast.jpg
Phear my phast motor icon!
Old 10-25-2003, 04:41 PM
ridealot100
you just need to make a custom charger. i have a thread that i will soon be making a tutorial for tricelling and making a custom charger
go to 13.5mhp microsizer!!!!!
Old 10-26-2003, 04:55 PM
Lube Master
im using a 4.5v 500mah charger.... I put it on for 3 minutes... mabey too low amperage
Old 10-27-2003, 01:56 PM
SlowbutCourious's Avatar
State Property
...if i'm not mistaken ( witch i might be ) the Laymans mod does not have the same results as a bit with 2 cells ....if u got some cash 2 blow go get 3 watch batts. put some tape around them and pop them in your car...tho u will not be able 2 recharge them your car will SCREAM...
Old 10-27-2003, 04:41 PM
actofgod actofgod is offline
Bit Surgeon
Smurf,
Like ridealot100 said, you'll have to build a custom charger using a battery pack (AA's) or an AC-to-DC adapter. I use 4.5v 500mAh also. If properly charged, a layman's tri cell will be as fast as any dual cell using standard 1/3AAA batt's, but it will not run as long between charges. However, it will be more controllable since it has much less weight. Any one who has done a dual cell will tell you that it is not very good for driving on tracks, just for drag racing or messing around since you spin out so much.
If you really want to have some fun, once you get the layman's tri cell working, ship it off to microamps to do the mosfet mod. It's a great low-weight combination!
Good luck.
Laymans Tricell Link AE86 Toyota Bit Char-G / MicroSizers 5 03-28-2006 10:30 PM
The Radioshack Layman's Tricell baterries charliebrown ZipZaps 22 03-14-2004 09:17 PM
Laymen's tricell problems NatakuARN ZipZaps 3 02-02-2004 07:44 PM
No wonder my Layman's Tricell wasn't working! charliebrown ZipZaps 1 01-26-2004 05:17 PM
layman's tricell charging question Snow Bit Char-G Mods and Projects 0 11-28-2003 07:06 PM
