Old 09-20-2003, 01:29 PM
BabyKiller's Avatar
my lowered se
+ (4.8v)
Old 09-20-2003, 02:28 PM
Bad Company's Avatar
Nice work babykiller! Now take those lights out and slaaaammmm that thang!
Old 09-20-2003, 07:18 PM
BabyKiller's Avatar
its about as low as it goes without a body kit like you did with yours
+ (4.8v)
Old 09-20-2003, 07:21 PM
Did you remove the LED PCB under the roof and the tabs that hold it? If not, it WILL go lower. I removed all that and got another 1/16" lower even without the body skirts.
When you have it as low as it goes, you will not have any space between the front tire and the fender. Take another look at mine again.
Old 09-20-2003, 07:25 PM
BabyKiller's Avatar
yes have it out and believe it or not i did that lowering with no modding for the front take the springs out and the back just push the tab up higher in the body than the hole but if you try this its not my falt if you break you tabs :P
+ (4.8v)
Old 09-20-2003, 07:29 PM
This is as low as it goes, and you have to remove the LED PCB and tabs. You will notice that even with the skirts, the main body is a lot lower than the original. Notice the wheels tucked up under the fenders.
Old 09-20-2003, 07:37 PM
BabyKiller's Avatar
so i achived mine with no modding i feel soo speacial
+ (4.8v)
Old 09-20-2003, 08:40 PM
And as I said, Nice Work! I was only stating that it can go lower without the appearance of the skirts as you said was the reason mine looked so low.
Old 09-21-2003, 07:01 AM
BabyKiller's Avatar
time o break out the dremel
+ (4.8v)
Old 09-21-2003, 07:02 AM
BabyKiller's Avatar
btw did you make those skirtsif not whered you get them?
+ (4.8v)
Old 09-21-2003, 09:14 AM
I made them out of stacked styrene sheets. You can get it at the local hobby shop. You can see more about it in the other thread.
Finally lowered my rx7!!! AE86 Toyota Bit Char-G / MicroSizers 4 03-28-2006 02:54 PM
Lowered L-ion GT40 LBRC Mini-Z - Mini-ZRacer.com 3 12-23-2004 11:57 PM
lowered truck pictures biohazard Bit Char-G / MicroSizers 48 05-21-2003 11:50 AM
Lowered bit? Trouble with wheel rub on fenderwells? NorCalCoug Bit Char-G Mods and Projects 1 10-17-2002 12:13 PM
test post... lowered Honda? tuner00 ZipZaps 11 10-08-2002 03:27 PM
