Old 09-03-2003, 11:06 PM
I Shall Return!
PCB capacity
currently i am running a quad cell ZZ utilizing a 4.2pro motor... this thing is a beast i showed my friends and none of em wanted to race i even offered to run in reverse... thats not wuts important wut is important is that its gettin decent accel of the line with red gears but i want it like a bullet so i figure more current is required... low and behold some1 posts a simple resistor bypass and im hooked... its like frikin cat nip for zaps (its wut i need!!!) ne ways i wus wonderin if my pcb can handle this mod... my batts r 4X( 40Mah 1.2V ) from allelectronics.com and i kno how this mod reduces runtime by 1/2 so ima only bypass the resistor for foward ( while doin the mod its the resistor farthest from u or higher up 1)
2 recap... can my pcb handle a resistor bypass using my setup?? ur will it fry
Note: sry for long thread, and my sig is wuts 2 come of my car so watch out... also i emailed this question to all the moderators but only payaso replyed so thnx payaso... i jus wanna b sure this is my 1 and only ZZ
Old 09-04-2003, 01:50 PM
BabyKiller's Avatar
only ,thing i can think of is a mosfet that bypasses all resistors running to the motor
+ (4.8v)
PCB Not working (Strange Dual battery symptoms) kenny_dilger Bit Char-G / MicroSizers 0 12-16-2002 10:59 PM
Another Sucessful PCB Transplant marc515192 Bit Char-G / MicroSizers 6 10-27-2002 09:22 PM
Another Sucessful PCB Transplant! marc515192 ZipZaps 0 10-27-2002 03:37 PM
Zipzap motor and PCB dtmracer ZipZaps 4 10-17-2002 05:01 PM
