08-23-2003, 08:24 PM
Questions for Ahh5hit
im a total newbie when it comes to zipzaps cuz i just got mine 2 days ago. (i live in Richmond Canada so its really hard to get more) and i have some questions about some mods.
1) What is the best way to lower your zipzap and how do you do it?
2)Where can i find or how can i make an exhaust for my zipzap.
3)Any tips on how to paint decals or what kinds of paints to use?
4)What techniques to use when painting?
I would love to see Ahh5hit answer these questions or anyone else.
5)This one is just for Ahh5hit, where do u get ur zipzaps and how many do u have?
PS. I have an 2f2f eclipse, evo, and a 350Z if that matters
PPS. sorry its so long but i have a lot of questions and i need answers.
Brooklyn beast
08-23-2003, 08:47 PM
Re: Questions for Ahh5hit
I like to tab lower the chassis, this way you can use it on multiple bodies. Just perform a search for "tab lowering" and you will find a tutorial I did.
You can find them on the Import Tuner diecast. I have started using little aluminum tubes you cab get at the LHS. Also, roll sring pins can be found at hardware stores.
I don't paint decals. I use Dupli Color automotive spray paint, it goes on really thin and even.
If using rattle cans, use several light layers from about 12" and take your time. I usually do 2 passes at a time, with about 5 cycles.
5)This one is just for Ahh5hit, where do u get ur zipzaps and how many do u have? I buy them where everyone else does, Radioshack. I have at least 1-2 of every body and chassis, and lots of extras that I have modded. I have around 40 some chassis, and at least 60 bodies.
08-23-2003, 08:50 PM
Modder-Eater
Trace the tab on the zipzap onto a credit card and cut that piece out. dremel/x-acto off the original tab and glue the other one below the original tabs spot. See Ahh5hit's thread for images to be clearer on it. Use the search button at the bottom of the page!
You can support Tiny and buy one here, or use a metal antennae (cut down) or a pen tip.
decals are water transfer stickers. no painting involved. just print (or buy), wet, slide off paper.
Make sure you mask your windows with masking tape, use smooth strokes left and right when spraypainting/airbrushing. dont let off the spray while you are in the middle section of the car. this causes any paint spatter to splat all over the car. spray long strokes all the way across from side to side.
hope that helps
08-23-2003, 09:31 PM
Wow it took like 3 minutes for 3 answers thanx guys.
But about the decals, i meant is there any way to paint your own?
And what types of paints should i use?
and Ahh5hit u still didnt answer my question about where u get ur zipzaps.
Also can someone tell me how do to a dual cell step-by-step
and what is the best gear/motor combo? (eg. blue nos motor with red gears)
thanx guys
Brooklyn beast
08-24-2003, 07:53 AM
I did answer your question, I get them at Radioshack. The manager here can even get ahold of the retired kits too. That is how I got all the past kits that I missed before I started this hobby.
08-24-2003, 04:57 PM
Which radio shack is that? (i live in richmond B.C. too)
Also do you have to order them or are they in stock?
(is the radioshack in canada or u.s.a.?)
And can someone answer the question about decals.
thanx ahh5hit and ziprc
Brooklyn beast
08-25-2003, 03:57 PM
I mainly get mine from one of three RS here in Richmond, VA. I also purchase from the 1-800 number when I have the item number before stuff is on the site or in stores.
08-25-2003, 07:27 PM
can you give me the address and phone number to one of them?
Brooklyn beast
