Old 08-21-2003, 04:04 PM
LittleBlueRocke LittleBlueRocke is offline
Dr. Pepper Warlord
Is it true???
I read somewhere that the controller only half charges the battery.Is it true???Should I double charge my Micro?I have a Micro Pro,if that makes any difference.Also,should I do any mods to it right away to make it better?I already plan on adding tires,an r-spec motor,and a stabilizer kit.Maybe springs???
Thanks!
Original 27 MHz Blue Skyline MicroSizer RIP
New MicroSizers Pro
Old 08-21-2003, 05:44 PM
SkyLiNEz 4-eva!
only on the first time, but whoever told you that is made of crap.
Old 08-21-2003, 08:26 PM
SuperFly's Avatar
SuperFly SuperFly is offline
bitPimp
I routinely triple charge my cars and it works fine. You'll get longer runtimes. Actually it is Skylinez 4-eva that is full of crap, the standard charge from the standard controller only uses a portion of the battery capacity. Double and triple (even quadruple) charges will give you longer runtimes, perhaps at the expense of overall battery life. But, I have yet to wear out a battery and I drive quite a bit, although my driving is split between 5 or so cars.
Look up some of Namuna's posts regarding battery capacity, milliamps, and milliamps per hour if you really want to know what's going on.
There is no difference between a Microsizer original and a Pro from a battery standpoint.
If you're looking at mods and are interested in batteries and runtime, upgrading the battery to one with a higher capacity is a good mod. Of the other mods you mentioned, you will get the least noticeable difference from changing the stabilizer. I woudn't do springs until you've driven for a while and feel like you have a problem that springs will fix. To me, the surface you are driving on has more to do with how a car handles than any of the mods you might do.
Old 08-21-2003, 08:29 PM
eman1 eman1 is offline
custom title
Send a message via AIM to eman1
Get a 200mah battery. And the answer is yes, you should charge it twice.
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
Old 08-21-2003, 08:45 PM
Dr. Pepper Warlord
I wish I had the tools and the steady hand to do a battery swap.I am probably just going to get a new motor,and maybe fool around with the tires and stabilizers for the heck of it.
Would the R-Spec be a good motor?I want awesome speed,but some torque,too.
New MicroSizers Pro
Old 08-21-2003, 09:14 PM
Namuna's Avatar
Namuna Namuna is offline
#1: The answer to the original question is no, it doesn't 1/2 charge the battery...It's more like 1/4 charge
2 or 3 consecutive charges will produce quite a bit more runtime.
#2: SkyLiNEz 4-eva! I guess there's just no reform for some people. It's one thing to put out wrong info, but you feel the need to claim that any other info is full of it? You're out of here chief.
#3: eman1 I'll ask you to hold back from any form of retaliation. If someone posts something inflammatory, use the 'report this post to a moderator' link to report it. You're only going to get yourself in trouble along with the offender from doing such things.
Old 08-21-2003, 09:32 PM
custom title
alright sorry, i edited my post.
And a battery swap isnt hard. The first time i did it i was practically shaking. It was almost funny. I did it successfully. Just use a really small screwdriver to slowly push the wires out of the way. Then use the screwdriver to pry out the battery.
Ive done it three times so far. The second and third times i just did it today, it wasnt hard at all. Took under 30 seconds each.
current parts:
auto modellista
4.2 pro
Pullback wheel mod
Old 08-21-2003, 11:51 PM
ucfdan ucfdan is offline
HAHA swapping the battery is the only thing I allow myself to perform after trashing innocent bits. I have to accept my own metiocrity and not disect,LOLLOL
Can This Be True??????? harolife SuperSlicks 5 03-14-2004 06:23 PM
My true blue pearl sky... unicorn_456 XMODS Gallery 9 11-04-2003 08:03 PM
is this true?? please read and reply tmdz28 Auldey (All) 13 10-17-2003 11:44 PM
true or not true Rcdude7378 Bit Char-G / MicroSizers 9 10-26-2002 02:12 AM
